2020-04-20Revert "samba: add quota to the DEPENDS"Verdin-iMX8MM_Console-Image_3.0b4.254-20200421Colibri-iMX8X_Console-Image_3.0b4.254-20200421Colibri-iMX7_Console-Image_3.0b4.254-20200421Colibri-iMX7-eMMC_Console-Image_3.0b4.254-20200421Colibri-iMX6_Console-Image_3.0b4.254-20200421Colibri-iMX6ULL_Console-Image_3.0b4.254-20200421Apalis-iMX8_Console-Image_3.0b4.254-20200421Apalis-iMX8X_Console-Image_3.0b4.254-20200421Apalis-iMX6_Console-Image_3.0b4.254-20200421Apalis-TK1_Console-Image_3.0b4.254-20200421Apalis-TK1-Mainline_Console-Image_3.0b4.254-20200421thud-nextthudMax Krummenacher
This dependency is not needed anymore and without further changes now makes do_configure even fail. So we drop this. Do configure samba with quota installed the following additional entry to meta-networking/files/waf-cross-answers/cross-answers-arm.txt would be needed: checking for clnt_create(): OK This reverts commit 1ea8042efa053e94c011d4b2e8835cf4e2e05ad6. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2020-04-20README: rework for thud branchesMax Krummenacher
2020-04-10Revert "tdx-extra: disable backports for terga k1"Marcel Ziswiler
Now that it works for downstream Apalis TK1 as well. This reverts commit a4b47fa3a664dd36b5f500d49fccb0946882c4b9.
2020-04-04tdx-extra: disable backports for terga k1Oleksandr Suvorov
The ASYMMETRIC_KEY_TYPE support is broken in kernel 3.10. This option required to build backports. Remove backports from tk1 images. Related-to: ELB-2388 Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
2020-04-03tdx-extra: enable backports accross all modulesMarcel Ziswiler
Related-to: ELB-2388 Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2020-03-24tdx-extra: Use udev rules for symlinking toradex interfacesPhilippe Schenker
2019-10-15tdx-extra: deploy libgpiod and toolsVerdin-iMX8MM_Console-Image_3.0b3.118-20200101Colibri-iMX8X_Console-Image_3.0b3.118-20200101Colibri-iMX7_Console-Image_3.0b3.118-20200101Colibri-iMX7-eMMC_Console-Image_3.0b3.118-20200101Colibri-iMX6_Console-Image_3.0b3.118-20200101Colibri-iMX6ULL_Console-Image_3.0b3.118-20200101Apalis-iMX8_Console-Image_3.0b3.118-20200101Apalis-iMX8X_Console-Image_3.0b3.118-20191231Apalis-iMX6_Console-Image_3.0b3.118-20191231Apalis-TK1_Console-Image_3.0b3.118-20191231Apalis-TK1-Mainline_Console-Image_3.0b3.118-20200101Max Krummenacher
This allows on newer (>=4.8) kernels to access the new gpio interface through /dev/gpiochipX character devices. https://git.kernel.org/pub/scm/libs/libgpiod/libgpiod.git/tree/README Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-10-11tdx-extra.inc: Add entropy daemonOleksandr Suvorov
Linux kernels >= 4.8 lack of strong entropy after boot. This leads to long delay in starting wide class of applications like ssh, qterminal etc. Adding entropy helper service fixes this issue. - add haveged daemon for tegra soc series - add rng-tools for all other soc series. Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
2019-09-30tdx-extra: add additional toolsMax Krummenacher
With the move away from angstrom we lost some networking and debugging tools which angstrom did install by default. Add them again here. avahi-autoipd ppp procps strace Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-08-07tdx-extra.inc: add bmode-usb to imx6ullColibri-iMX8X_Console-Image_3.0b2.65-20190830Colibri-iMX7_Console-Image_3.0b2.65-20190830Colibri-iMX6_Console-Image_3.0b2.65-20190830Colibri-iMX6ULL_Console-Image_3.0b2.65-20190830Apalis-iMX8_Console-Image_3.0b2.65-20190830Apalis-iMX6_Console-Image_3.0b2.65-20190830Apalis-TK1_Console-Image_3.0b2.65-20190830Apalis-TK1-Mainline_Console-Image_3.0b2.65-20190830Philippe Schenker
2019-07-11x-window-simple-app: rdepend on xserver-nodm-initMax Krummenacher
Add the missing RDEPENDS. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-07-10tdx-extra.inc: use the generic name u-boot-fw-utilsMax Krummenacher
The machine.conf sets the needed u-boot-fw-utils flavour with PREFERRED_PROVIDER. Thus us the generic u-boot-fw-utils in IMAGE_INSTALL. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-07-10tdx-extra.inc: deploy util-linux for all machinesMax Krummenacher
This installs the full featured util-linux applications and preferes them over the busybox variants at the price of a bigger rootfs. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-07-01joe: update to 4.6Max Krummenacher
Backport from patch in meta-openembedded ML. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-07-01base-files: rework /etc/profileMax Krummenacher
Put the changes we want to make to the default into scripts in /etc/profile.d and keep the openembedded-core provided /etc/profile. This keeps the maintained version of /etc/profile rather than having to manually merge in fixes from the openembedded layer. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-06-24lxde-image: mark as incompatible with i.mx8Max Krummenacher
2019-06-24tdx-extra: follow changed machine nameMax Krummenacher
Related to: #49287 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-06-21tdx-extra.inc: drop backports for all but TK1Max Krummenacher
The Wi-Fi drivers from kernel 4.14 provide all needed features. So don't bother with backports. While at it move all Wi-Fi related packages into the Wi-Fi variables. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-06-21packagegroup-core-x11: don't rdepend on any display managerMax Krummenacher
We want to choose different display managers for different image recipes. Thus do not inject one through this packagegroup. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-06-16gpio-tool: provide all binaries strippedMax Krummenacher
The gpio-tool recipe declares all binaries as stripped. The packages qa check fails now if the binaries are not stripped as follows: | ERROR: gpio-tool-1.0-r3 do_package: QA Issue: gpio-tool: Files/directories were installed but not shipped in any package: | /usr/bin/.debug | /usr/bin/.debug/gpio-tool | Please set FILES such that these items are packaged. Alternatively if they are unneeded, avoid installing them or delete them within do_install. | gpio-tool: 2 installed and not shipped files. [installed-vs-shipped] Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-06-11wayland-app-launch: fix service status detectionApalis-iMX8_Console-Image_3.0b1.40-20190612Max Krummenacher
The service expects the script to return (Type=forking). Change the script so that the wayland app is started in the background. While at it configure the service to restart the application. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-06-05qt5-x11-image: add i.mx8 gstreamer pluginsMax Krummenacher
2019-06-05qt5-x11-image: unify with lxqt imageMax Krummenacher
2019-05-29console-tdx-image: rework starting a graphical appMax Krummenacher
Include a launcher for the weston-terminal if built for wayland/xwayland. Rework that the X11 launcher is only used if not using xwayland. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-05-29wayland-app-launch: add a simple systemd serviceMax Krummenacher
This tries to start a wayland application after weston got started. Create a copy of wayland-terminal-launch_1.0.bb with the variables changed according to your needs. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-05-29x-window-simple-app: fix rdependsMax Krummenacher
RDEPENDS is set by bitbake to an empty string, so using ?= is pointless. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-05-22cpuburn-a53: don't link with staticMax Krummenacher
This reduces the binary from 400 to 4k. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-05-22images: cleanupMax Krummenacher
packagegroup-base-extended is installed by inheriting core-image. packagegroup-basic installs dropbear, openssh-sftp, openssh-sftp-server dropbear can act as an scp client, drop openssh-scp Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-05-22images: simplify prepending a machine nameMax Krummenacher
Define the string used for each machine in the machine configuration rather than doing this in each image recipe. Fallback to machine configuration name if not defined. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-05-22images: drop angstrom specific variablesMax Krummenacher
2019-05-22tdx-extra: mx8: add u-boot fw-utilsMax Krummenacher
2019-05-22tdx-extra: mx8: add addional toolsMax Krummenacher
2019-05-22tdx-extra.inc: set PV to the BSP versionMax Krummenacher
We used to do this in the dropped tdx-image-fstype.inc. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-05-22console-tdx-image: wayland; install a graphical backendMax Krummenacher
If a build is configured for a wayland or xwayland graphical backend install an sample application too. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-05-22console-tdx-image: autostart xtermMax Krummenacher
Without this xinit fails because /usr/bin/x-window-manager does not exist and systemd then indefinitely retries to start X11. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-05-22x-window-xterm: add recipeMax Krummenacher
This recipe starts xterm as the first X11 application. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-05-22x-window-simple-app: create common inc file and rename recipeMax Krummenacher
Pull out common code so that the bb file only contains information about the application which is to be started. Rename the recipe so that one knows what is going to be started. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-05-14Revert "angstrom-qt5-x11-image.bb: workaround ordering of populate_sdk ↵Max Krummenacher
populate_sdk_qt5" This reverts commit 0af5df0bd71d1714c1b2623fd9f6d57619926278. meta_qt5 got fixed so that it is no longer needed to force an inherit order. This prevents that with every build of the image the sdk is also built. Also apply the same to lxqt-image. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-05-13console-tdx-image: fix python callMax Krummenacher
2019-05-08tinycompress: import recipeMax Krummenacher
Import from meta-fsl-bsp-release @ sumo-4.14.78-1.0.0_ga Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-05-08images and helpers: drop qt4Max Krummenacher
Qt 4 was first released in 2005 and has been unsupported since 2015. Drop it from what we regularly install. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-05-04images: install the xserver depending on distro featuresMax Krummenacher
This is a follow-up to: e1026cf43 images: do not explicitely install ${XSERVER} Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-05-02cpuburn: add a cortex-a53 versionMax Krummenacher
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> (cherry picked from commit 832e3954f29df6ce1f5cc385ebefa2ef7f27ebd0)
2019-05-02clpeak: add recipeMax Krummenacher
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> (cherry picked from commit 2bba608252c7c09447e94bbacf8b1310113b12ff)
2019-04-25conf/layer.conf: decrease layer priority to 24Max Krummenacher
2019-04-24qt5-x11-image: cope with xwayland or native x11Max Krummenacher
2019-04-24lxqt-image: also deploy libdrm-testsMax Krummenacher
This among others installs modeprint, modetest. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-04-23colibri-vf: drop machineMax Krummenacher
We decided we won't do a BSP 3.0 for Vybrid. For new designs we recommend ULL now. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-04-23images: drop the legacy update procedureMax Krummenacher
Use the Toradex Easy Installer instead. If you included tdx-image-fstype.inc in your image recipes you will have to remove that include. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-04-21lxqt-image: cope with xwayland or native x11Max Krummenacher
