We want to append to the generic VAR when we build for a tegra machine.
Using VAR_tegra += "" creates a machine specific VAR.
Use Stefan's patch until it is available from the meta-openembedded jethro branch.
http://cgit.openembedded.org/meta-openembedded/commit/?h=master-next&id=bf8f27af3954ab68e39712516ab515de90b4db27
Add a .desktop file to get a start menu entry for the webkitgtk
browser MiniBrowser.
Currently _tkinter is only built when tcl/tk is available before the
python do_configure task is built.
Make this deterministic by providing a PACKAGECONFIG for it.
If tkinter is in PACKAGECONFIG add the needed dependencies,
if not force that tkinter is not built.
Note that currently enabling tkinter does not work due to a cyclic
dependency:
'python' depends on 'tk/tcl' depends on 'cracklib' depends on 'python'
The Linux Kernel 4.4 for Colibri VF does currently not support the needed
interfaces for mcc.
meta-angstrom unconditionally includes stuff from meta-qt5.
e.g. look for files in ${board} subdirectory rather than in the media's root.
midori_*bb has been removed.
follow
http://cgit.openembedded.org/openembedded-core/commit/meta/classes/mirrors.bbclass?id=9560d58596ceb50280b81296688883f3fca99aa6
This avoids:
WARNING: Invalid protocol (svk) in PREMIRRORS: svk://.*/.* http://sources.toradex.com/V2.5/
Newer xserver recipes dropped some packages, move them to RRECOMMEND
rather than adding it to IMAGE_INSTALL. That way the image build
independently of the used xserver version.
midory has been dropped from oe-core
When building for a second machine after building for one the rootfs
creation fails because some license files are not found.
I belive this is caused by the following commit:
https://github.com/Angstrom-distribution/meta-angstrom/commit/dae094d69a1f8651c822fb35d606bf59a615f244
All packages which are created from sstate fail do install in the rootfs
likely because the license file is only available in the subdirectory of
the machine for which it was originally built.
machine/u-boot/kernel files have been added to meta-fsl-arm-extra.
Use them from there now.
Write kernel and device tree into seperate UBI Volumes. This
allows to use a lot less UBI/UBIFS support in U-Boot, which
should lower the risk of hitting bugs in this area. Boot times
are also slightly faster (measurements showed an improvement of
~150ms).
Enable USB suspend resume fix for Vybrid.
Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
When using TFTP update, the rootfs must be in decimal numbered chunks on the
tftp server. U-Boot reads the chunks, but does count hexadecimal thus
limiting the number of chunks to 10.
The U-Boot binary for the IT temperature range changed names from
u-boot-it.imx to u-boot.imx-it.
The flash_*.scr scripts did still use the old name resulting in the U-Boot
not being found on the SD card or TFTP server.
Avoids
WARNING: Unable to get checksum for gpioconfig SRC_URI entry GPIOConfig: file could not be found
during recipe parse by providing a dummy GPIOConfig.
The dummy displays a popup with a button that says that the program is not
available on this machine.
(cherry picked from commit e6959294ac99c87c7aabe2334d6582618ea3a825)
