2015-05-12 | opencv: add patches for libav 10.x API | Max Krummenacher | |
2015-05-12 | graphviz: update to 2.38, not working | Max Krummenacher | |
Neiter graphviz_2.32.0.bb graphviz_2.38.0.bb work with dizzy. Uses python directory from build host. | |||
2015-05-12 | recipes: replace short DESCRIPTION with SUMMARY | Max Krummenacher | |
The SUMMARY variable gives a short description of the package (<72 chars). A missing DESCRIPTION is automatically set to the content of SUMMARY. | |||
2015-05-12 | recipes: don't use ${PN} as a recipe name placeholder | Max Krummenacher | |
${PN} might be extended with some magic prefix, so don't use it in SRC_URI assignments et. al. | |||
2015-05-12 | imlib2: remove bbappend, fixed in bb | Max Krummenacher | |
2015-05-12 | lxde-common: use generic panel-buttons.patch | Max Krummenacher | |
There is no difference between iMX6 / Tegra based modules | |||
2015-05-12 | lxde-common: remove screenlock from panel | Max Krummenacher | |
2015-05-12 | lxde-common: move version to % placeholder | Max Krummenacher | |
remove consistent_defconfig_dirs.patch as it is no longer needed starting with 0.5.6 consistent_defconfig_dirs.patch is no longer needed. change bbappend to contain % instead of the version | |||
2015-05-12 | lx.inc: cleanup with meta-lxde packagegroup | Max Krummenacher | |
Add the lxde components with meta-lxde packagegroups and the window and display manager here. | |||
2015-05-12 | lx.inc: remove packages pulled from packagegroup | Max Krummenacher | |
Don't explicitely add packages already added by the lxde package group. | |||
2015-05-12 | i2ctools: don't install the perlscript and perl | Max Krummenacher | |
Mechanism changed to what the bb file now offers. | |||
2015-05-12 | icu: upgrade reduced icu data to version 53 | Max Krummenacher | |
While at it move version to % placeholder and use wildcards in receipe icu: use wildcard to be independent of version | |||
2015-05-12 | Apalis/Colibri iMX6 build kernel uImage | Max Krummenacher | |
The default changed to zImage so explicit set uImage for now. While at it cleanup the recipe, remove pci from Colibri machine features. | |||
2015-05-12 | local.conf: update the distro version to its dizzy value | Max Krummenacher | |
2015-03-31 | images: change to V2.4 | Max Krummenacher | |
2015-03-31 | gvfs: remove samba from PACKAGECONFIG | Max Krummenacher | |
compiling gvfs with samba support in dizzy does not only pull in smbclient but the full samba package, i.e. 50MB+. | |||
2015-03-31 | gnutls: remove bbappend | Max Krummenacher | |
gnutls recipe now detects pthread in configure task correctly. | |||
2015-03-31 | images: use changed gdb-cross package name | Max Krummenacher | |
2015-03-31 | images: use packagegroup instead of task | Max Krummenacher | |
2015-03-31 | giblib: use autotools-brokensep | Max Krummenacher | |
2015-03-31 | dropbear: remove unused bbappend | Max Krummenacher | |
2015-03-31 | qt4: replace version with % wildcard | Max Krummenacher | |
While at it replace Tegra machines with SOC family Conflicts: recipes-qt/qt4/qt4-x11-free_4.8.5.bbappend | |||
2015-03-31 | FILESEXTRAPATHS_prepend: add proper list separator | Max Krummenacher | |
2015-03-31 | lxde-icon-theme: move version to % placeholder | Max Krummenacher | |
2015-03-25 | Update release notes | Marcel Ziswiler | |
2015-03-19 | colibri-vf: update to top of -next branch | Stefan Agner | |
Update to top of -next branch which also includes FEC unbind fixes. | |||
2015-03-10 | usb-rndis: fix various issues with dhcpd service for RNDIS | Max Krummenacher | |
- Make sure leases file is not persistent (in /var/run now) This allows to serve the same IP to the generated (and hence different IP addresses) - Start RNDIS service after the network.target - Tegra: Add extra service for udhcpd. When running dhcpd directly from udev, the daemon will be killed after a while | |||
2015-03-05 | journald: remove journald.conf patch | Max Krummenacher | |
meta-angstrom now overrides the effect of the patch and provides the journald.conffile in full. To override a setting either create the file with your settings in meta-toradex/recipes-core/systemd/systemd/journald.conf or edit meta-angstrom/recipes-core/systemd/systemd/journald.conf. | |||
2015-02-17 | qt-demo-init: converted to systemd service | Stefan Agner | |
Convert qt-demo-init to a systemd service. The service will only start when the systemd target is set to graphical, hence also set the new default target of the qt4e-demo-image to graphical. | |||
2015-02-12 | Update release notes | Marcel Ziswiler | |
2015-02-12 | mmc-utils: add recipe for chromiumos version thereof | Marcel Ziswiler | |
Add a recipe for the Chromium OS version of the mmc-utils able to handle Extended CSD revision 1.7 of the latest MMC 5.0 specification. Some of the more interesting information thereof is the life time estimation and pre EOL information as follows: root@apalis-t30:~# mmc extcsd read /dev/mmcblk0 | \ grep -A 3 'Device life time estimation type A' Device life time estimation type A [DEVICE_LIFE_TIME_EST_TYP_A: 0x01] i.e. 0% - 10% device life time used Pre EOL information [PRE_EOL_INFO: 0x01] i.e. Normal | |||
2015-02-06 | Apalis/Colibri iMX6: Update release notes | Max Krummenacher | |
Add issue with getty also started on ttymxc1. | |||
2015-02-04 | Colibri VF50/VF61: Update release notes | Stefan Agner | |
2015-02-03 | colibri-vf: update Linux kernel and U-Boot git hashes | Stefan Agner | |
Also update default defconfig for colibri-vf. | |||
2015-01-23 | rdesktop: workaround issue witherial forwarding | Max Krummenacher | |
2015-01-20 | apalis/colibri-imx6: Fix serial console tty | BhuvanChandra.DV | |
This patch fixes the issue of getting serial tty login at ttymxc1 (UART_B). Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com> | |||
2015-01-14 | qt4-x11-free: append to DEPENDS, not overwrite it | Max Krummenacher | |
2015-01-13 | Apalis iMX6: Update release notes for Beta6 | Max Krummenacher | |
2015-01-12 | feeds: remove debug and re-add hard-float non-neon feeds | Marcel Ziswiler | |
Remove debug feed URL as it does not exist. Re-add Colibri T20 specific (ARM, hard-float, non-neon) feeds which recently are built in Angstrom again as Atmel SAMA5D3 is non-neon as well. | |||
2015-01-09 | u-boot: build additional binary for Apalis iMX6Q 2GB IT | Max Krummenacher | |
The IT variant needs different RAM timings | |||
2015-01-09 | Apalis iMX6: Update release notes | Max Krummenacher | |
2015-01-09 | rdesktop: add rdesktop recipe | Marcel Ziswiler | |
2014-12-19 | Apalis/Colibri iMX6/T20/T30/VF50/VF61: Update release notes | Marcel Ziswiler | |
2014-12-19 | Apalis iMX6/T30 & Colibri T20/T30/VF50/VF61: fix GPIOConfig | Marcel Ziswiler | |
2014-12-19 | colibri-imx6: add u-boot-fw-utils | Max Krummenacher | |
2014-12-19 | u-boot/u-boot-fw-utils: update all to latest | Max Krummenacher | |
2014-12-19 | colibri_vf: update U-Boot and Linux kernel git hashes | Stefan Agner | |
Two last minute fixes: Default Product/Vendor ID for USB peripheral in U-Boot and fix for the USB peripheral RNDIS freeze. | |||
2014-12-18 | Update all to latest and greatest U-Boot and Linux kernel. | Marcel Ziswiler | |
2014-12-18 | GPIOConfig: update with mainline kernel support | Stefan Agner | |
2014-12-18 | mcc-pingpong: alter CFLAGS to use the actual kernel headers | Stefan Agner | |
To use the kernel interfaces required for mcc-pingpong we need the kernel headers of the actual kernel. Alter CFLAGS to add the kernel headers to the include path. |
