2013-07-26 | openssh: give the subpackages there own -dev, -dbg | Max Krummenacher | |
this allows a debug installation of dropbear with openssh-scp, openssh-sftp and openssh-sftp-server | |||
2013-06-27 | release notes: updated to T30_LinuxImageV2.0Beta2_20130626 ↵ | Max Krummenacher | |
Apalis_T30_LinuxImageV2.0Beta1_20130626 | |||
2013-06-27 | release notes: add all release notes 2013-05 | Max Krummenacher | |
2013-06-26 | image: move the pixbuf loader update to rootfs creation | Max Krummenacher | |
2013-06-26 | u-boot: update to latest git revision | Max Krummenacher | |
2013-06-26 | gdk-pixbuf: update icon cache on rootfs build time | Max Krummenacher | |
2013-06-26 | systemd: fix patch path so the default -p 1 applies | Max Krummenacher | |
2013-06-26 | fs-init: add recipe to extend rootfs partition on eMMC | Max Krummenacher | |
- on Colbri/Apalis T30 the rootfs is downloaded in a minimum size. On first boot this filesystem is resized to fill its full partion. This slows down IO responsivness during the first 5 minutes. | |||
2013-06-26 | burnflash: unified T20/T30 | Max Krummenacher | |
- unified the burnflash sources to work on Colibri T20/T30, Apalis T30 - change the PXA dummy burnflash accordingly - increase the initial free rootfs space to 100M on eMMC partition will be resized on first boot to full partition size relevant for Colibri T30, Apalis T30 | |||
2013-06-26 | image: add gstreamer deinterlacer used with camera | Max Krummenacher | |
2013-06-17 | stress: download site is down, added mirror | Max Krummenacher | |
2013-06-07 | systemd-journald: limit journal size | Max Krummenacher | |
2013-06-07 | lxde-image: add scrot, add underscore to apalis tar filename | Max Krummenacher | |
2013-05-15 | unclutter: add recipe | Max Krummenacher | |
- Unclutter hides your X mouse cursor when you do not need it | |||
2013-04-25 | scrot: add scrot recipe, commandline screen capture utility | Max Krummenacher | |
2013-04-15 | mediainfo: added mediainfo recipe | Max Krummenacher | |
2013-04-15 | trdx-extra: cleanup indention | Max Krummenacher | |
2013-04-02 | florence: fix garbled titlebar | Max Krummenacher | |
2013-03-27 | images: added a QT4 X11 image | Max Krummenacher | |
- bbappends to the base qt4-x11-free recipe to use OpenGL ES2 - script which starts X plus qtdemo, including a systemd service to activate script | |||
2013-03-20 | florence: add virtual keyboard to image | Max Krummenacher | |
2013-03-20 | Wallpaper: correct new CI colors | Max Krummenacher | |
2013-03-07 | image: add setxkbmap package | Max Krummenacher | |
2013-03-04 | remove unused files | Max Krummenacher | |
2013-03-04 | lxde-common: wallpapers are MACHINE_ARCH dependent | Max Krummenacher | |
2013-03-04 | image: remove intermediate file before creating tarball | Max Krummenacher | |
2013-03-04 | added filesystem tools, Apalis: added lvds configuration scripts | Max Krummenacher | |
2013-02-15 | max9526: added a gtk version for Colibries only | Max Krummenacher | |
2013-02-06 | v4l-utils: fix for NULL not found erros | Max Krummenacher | |
2013-02-06 | python-numpy: backport fix of changed python-native path | Max Krummenacher | |
2013-02-06 | libfm: set lxterminal as the terminal application | Max Krummenacher | |
2013-02-05 | GPIOConfig: Colibri-t30 GPIO to SODIMM assignment | Max Krummenacher | |
- Colibri T30 V1.1 has a different assignment of GPIO to SODIMM pins | |||
2013-02-05 | firefox: bookmark the Toradex Cload Demos | Max Krummenacher | |
2013-02-05 | image: image name now defined in the image.bb files | Max Krummenacher | |
2013-01-29 | max9526: install on all modules | Max Krummenacher | |
2013-01-29 | wallpaper, change to new Toradex CI | Max Krummenacher | |
2013-01-29 | image: add Apalis-T30 specific packages | Max Krummenacher | |
2013-01-29 | base-files: add Apalis-T30 | Max Krummenacher | |
2013-01-29 | max9526: i2c userspace driver | Max Krummenacher | |
- sets some registers to setup chip on our ACM analog camera module board | |||
2013-01-29 | u-boot: add Apalis-T30 | Max Krummenacher | |
- add Apalis-T30 - remove u-boot machine definition, this is also defined in the machine conf. | |||
2013-01-29 | glmark2: add recipe for linaro glmark2 | Max Krummenacher | |
2013-01-29 | burnflash: add Apalis-T30 as a deployable image | Max Krummenacher | |
2013-01-29 | wallpaper, added Apalis-T30 | Max Krummenacher | |
2013-01-29 | kernel: unified the recipes for all toradex kernels | Max Krummenacher | |
2013-01-23 | wallpaper: renamed in preparation of upcomming Apalis | Max Krummenacher | |
2013-01-22 | GPIOConfig: fix issues with T30 | Max Krummenacher | |
- fix GPIO numbers > 222 not working correctly - fix handling of tristate - fix strings for first alternate function | |||
2013-01-22 | u-boot: update to latest on git.toradex.com | Max Krummenacher | |
2013-01-22 | kernel: update to latest on git.toradex.com | Max Krummenacher | |
2012-12-31 | update u-boot and kernel git versions | Max Krummenacher | |
remove testfile | |||
2012-12-18 | u-boot: remove all modification, they are moved to u-boot git | Max Krummenacher | |
2012-12-18 | kernel: update to latest on git.toradex.com | Max Krummenacher | |
