2014-03-18 | release notes: apalis/colibri t20/t30 colibri vf v2.1 beta 3 | Max Krummenacher | |
2014-03-18 | trdx-extra: apalis-t30: add additional camera drivers | Max Krummenacher | |
2014-03-18 | kernel vybrid: update to latest | Max Krummenacher | |
2014-03-18 | u-boot Txx: update to latest | Max Krummenacher | |
2014-03-18 | trdx-extra: add mcc components for vybrid | Max Krummenacher | |
The MCC (Multi-Core Communication) is the subsystem that enables MQX applications running on the M4 core to communicate with Linux applications on the A5 core | |||
2014-03-18 | trdx-extra: add gpioconfig to vybrid | Max Krummenacher | |
2014-03-18 | angstrom-lxde-image: T30: add gst-plugins-good-jpeg | Max Krummenacher | |
2014-03-17 | kernel/u-boot: update to latest git revision | Stefan Agner | |
2014-03-17 | GPIOConfig: add initial version for Vybrid | Stefan Agner | |
Add initial GPIOConfig for Vybrid (V1.0 Alpha 1) | |||
2014-03-17 | vybrid: backport Cortex-M utilites from meta-fsl | Stefan Agner | |
- Add utility mqxboot to load firmware into IRAM and reset M4 - Add kernel module mcc needed by libmcc - Add multi-core communication library libmcc for message queue based communication with Cortex-M core | |||
2014-03-06 | release notes: vybrid beta 2 release notes | Stefan Agner | |
2014-02-13 | release notes: apalis t30 | Marcel Ziswiler | |
Add a note concerning suspend LP1 being untested resp. it currently failing due to igb/PCIe issues. | |||
2014-02-10 | image: improved dependencies to make Qt image smaller | Stefan Agner | |
- move pam-plugin-ck-connector to LXDE image - remove connman-gnome from Qt image | |||
2014-02-10 | release notes: apalis/colibri t20/t30 v2.1 beta 2 | Marcel Ziswiler | |
2014-02-10 | kernel/u-boot: update to latest git | Stefan Agner | |
2014-02-05 | image: add kernel module for fusion touch screens | Stefan Agner | |
Add kernel module for Fusion 7"/10" touch screen to the root filesystem image. | |||
2014-02-04 | util-linux: add fstrim | Max Krummenacher | |
Add the fstrim utility to Colibri T30 image. The utility allows to send trim commands to the underlaying flash translation layer, which allows too free not used flash sectors and those improve wear- leveling | |||
2013-12-18 | stress: fix build, texinfo errors | Max Krummenacher | |
newer distro's tools give the following errors. stress.texi:68: @itemx must follow @item ported from meta-linaro: From e8ba4b6db2c3ec2be54f74d0177bbce2df3f0714 Mon Sep 17 00:00:00 2001 From: Riku Voipio <riku.voipio@linaro.org> Date: Mon, 1 Jul 2013 12:36:23 +0300 Subject: [PATCH] meta-linaro: fix stress build incompatible texinfo changes broke this build | |||
2013-12-02 | console-image: use connman | Max Krummenacher | |
2013-12-02 | kernel: update to latest git | Max Krummenacher | |
2013-11-21 | kernel: colibri-vf: use the unified kernel 50/60 | Max Krummenacher | |
2013-11-21 | u-boot: colibri-vf: use the unified u-boot 50/61 | Max Krummenacher | |
2013-11-21 | Machine: use the changed machinename colibri-vf | Max Krummenacher | |
2013-11-21 | qt4e-demo-image: Add missing libicui18n | Max Krummenacher | |
2013-11-21 | qtdemo-init: Add start script for qtdemoE | Max Krummenacher | |
2013-11-21 | Machine: remove Colibri VF50, now unified with VF61 | Max Krummenacher | |
2013-11-21 | qt4-embedded: configure for all supported screen depths | Max Krummenacher | |
2013-11-21 | lxde-common: choose wallpaper for colibri-vf at runtime | Max Krummenacher | |
2013-11-21 | Vybrid: add 'vf' to SOC_FAMILY | Max Krummenacher | |
2013-11-05 | Use double-quotes to make script work using dash (debian/ubuntu default) | Stefan Agner | |
2013-10-25 | release notes: colibri vf50 fix strapping resistor value | Marcel Ziswiler | |
2013-10-25 | release notes: colibri vf50 v2.1 beta 1 | Marcel Ziswiler | |
2013-10-25 | release notes: apalis/colibri t20/t30 v2.1 beta 1 | Marcel Ziswiler | |
2013-10-23 | glmark2: add missing dependencies | Max Krummenacher | |
2013-10-23 | u-boot: update to latest git version | Max Krummenacher | |
2013-10-23 | linux: update to latest git versions | Max Krummenacher | |
2013-10-21 | feed-config: use the new feed armv7ahf-vfp-neon for T30/VF50 | Max Krummenacher | |
2013-10-21 | hdmi: add udev rule to start an X output on hotplug | Max Krummenacher | |
2013-10-17 | evdev: backport V2.8.1 from dora | Max Krummenacher | |
V2.7.3 crash when it receives multitouch events | |||
2013-10-17 | inputrc: use <HOME> <END> to go to begin/end of line | Max Krummenacher | |
2013-10-17 | midori: add inital bookmarks and homepage | Max Krummenacher | |
2013-10-17 | lxpanel: add module dependent browser to launch bar | Max Krummenacher | |
For tegra use firefox, for vybrid midori | |||
2013-10-16 | build: fix cp destination in sample script | Max Krummenacher | |
2013-10-16 | vybrid: backport from meta-fsl-arm master-next | Max Krummenacher | |
remove when moving to dora branch | |||
2013-10-16 | machines: T30 and VF50 consitstently use NEON and hard float | Max Krummenacher | |
- Colibri T30 and Apalis T30 changed to NEON - Colibri VF50 changed to hard float This makes packages built for T30 incompatible with Colibri T20 (but Colibri T20 packages can still be used on T30) | |||
2013-10-16 | build: add a sample script for setting up the environment | Max Krummenacher | |
2013-10-16 | icu: fix SRC_URI | Max Krummenacher | |
2013-10-16 | local.conf: set sensible defaults | Max Krummenacher | |
2013-10-16 | bblayers: remove unneeded layer | Max Krummenacher | |
2013-10-16 | bblayers.conf: change path to meta-lxde | Max Krummenacher | |
