2014-07-15 | vnc: add directvnc and tightvnc recipes | Marcel Ziswiler | |
Two popular VNC clients: - DirectVNC based on DirectFB (e.g. without X11) - TightVNC based on X11 (cherry picked from commit ef4113208de357a5b8accd7610f8bf3230125a59) | |||
2014-07-15 | xinput-calibrator.service: only start when lxdm is enabled | Max Krummenacher | |
If the xinput-calibrator.service is enabled but lxdm.service is disabled lxdm was started anyway because of the requires dependency. Replase Requires with Requisite to have xinput-calibrator.service fail instead. (cherry picked from commit e34e6361ecaaa8b148d438d517761bdd084d1a32) | |||
2014-06-25 | qt5: config for gles and build examples | raul | |
2014-06-16 | trdx-image-fstype: improve for use with other images | Max Krummenacher | |
Don't fail for images which do not deploy /boot/uImage mx6: only strip binaries | |||
2014-06-12 | release notes: extend Colibri VF UART recovery notes | Stefan Agner | |
Add hint for non-fused modules, document recovery mode on Iris. | |||
2014-06-12 | apalis-imx6: remove unneeded variable | Max Krummenacher | |
2014-06-11 | virtual/kernel: set preferred unconditionaly | Max Krummenacher | |
Be consistent with the other machine recipes Help the autobuilder setup | |||
2014-06-10 | release notes: update Colibri VF release notes | Stefan Agner | |
Update Colibri VFxx release notes to reflect latest release V2.2 Beta 1. | |||
2014-05-28 | feeds: remove machine feed url, as it does not exist | Max Krummenacher | |
2014-05-28 | lxde-common: remove obsolete commands in autostart | Max Krummenacher | |
- remove workarounds for hdmiaudio and xrandr which are no longer needed. - while at it fix some whitespace issues | |||
2014-05-24 | colibri-vf: use latest u-boot and burnflash | Marcel Ziswiler | |
Use the latest U-Boot and burnflash. | |||
2014-05-20 | colibri-vf: switch back to latest git on colibri_vf branch | Marcel Ziswiler | |
This commit switches Colibri VF machine back to use the colibri_vf branch and use the latest Linux kernel. | |||
2014-05-09 | GPIOConfig: update Vybrid GPIOConfig tool | Stefan Agner | |
Update GPIOConfig for Vybrid (V1.2) | |||
2014-05-07 | linux-toradex: rename linux.inc to avoid layer order dependency | Stefan Agner | |
The include files (such as linux.inc) are not resolved by priority but on layer order instead. This can lead to build errors in case the layers in BBLAYERS are ordered differently. | |||
2014-05-07 | u-boot: make use of shared U-Boot branch | Stefan Agner | |
2014-05-02 | mcc-pingpong: demo application for ping pong with Cortex M4 | Stefan Agner | |
2014-04-30 | icu: add break iterator support for webkitgtk | Stefan Agner | |
Webkitgtk needs break iterator support in order to work. This avoids segmentation fault when using Midori web browser. | |||
2014-04-30 | colibri-vf: switch to U-Boot 2014.04 and latest git | Stefan Agner | |
This commit switches Colibri VF machine to use the 2014.04 git branch. The change to latest U-Boot brings proper NAND hardware ECC support, which is also enabled in latest Linux kernel. Beside that, burnflash is updated to correctly work with the new U-Boot version and the altered Config Block location. | |||
2014-04-08 | Added note about Apalis iMX6 SSH password authentication being | Marcel Ziswiler | |
disabled by default. While at it line wrapped Apalis T30 release notes document. | |||
2014-04-05 | u-boot-fw-utils: provide matching recipes | Max Krummenacher | |
With the change to our own u-boot recipes the bbappend to the common u-boot-fw-utils recipe is no longer a sane solution. While at it cleanup COMPATIBLE_MACHINE style. | |||
2014-04-05 | linux-toradex-fsl_git: fix parsing | Max Krummenacher | |
Make the bitbake parser not fail when this recipe is parsed for a machine for which this recipe is not a COMPATIBLE_MACHINE. | |||
2014-04-04 | Apalis_iMX6: add initial rlease notes | Max Krummenacher | |
2014-04-04 | icu: update to match bb version | Max Krummenacher | |
2014-04-04 | Revert "cortex-a5.inc: backport from openembedded-core dora branch" | Max Krummenacher | |
File now provided by openembedded-core This reverts commit 592b1395c7cdff2125b5e42a7f9605749e625419. | |||
2014-04-04 | bblayers.conf: add new required layers to defaults | Max Krummenacher | |
2014-04-03 | images: set PV to V2.2 | Max Krummenacher | |
2014-04-03 | gpu-viv-bin-mx6q: add bbappend for no samples | Max Krummenacher | |
adds gpu-viv-bin-mx6q-libraries package which RDEPENDS only the libraries but not the samples. | |||
2014-04-03 | images: apalis-imx6: don't deploy vivante samples | Max Krummenacher | |
2014-04-03 | kernel: apalis-imx6 update to latest git version | Max Krummenacher | |
2014-04-03 | u-boot: apalis-imx6 update to latest git version | Max Krummenacher | |
2014-04-02 | kernel: apalis-imx6 update to latest git version | Max Krummenacher | |
2014-04-02 | u-boot: apalis-imx6 update to latest git version | Max Krummenacher | |
2014-04-01 | images: add ptpd to apalis-imx6 | Max Krummenacher | |
2014-04-01 | machines: add colibri-vf, apalis-imx6 | Max Krummenacher | |
2014-04-01 | systemd-compat-units: ensure that postinst is run | Max Krummenacher | |
The combination of changes lead to the postinst scripts not beeing run at all. | |||
2014-04-01 | mimetypes: add mimetypes for some basic multimedia types | Max Krummenacher | |
2014-04-01 | glmark2: remove recipe in favor of meta-openemebedded | Max Krummenacher | |
2014-04-01 | image: Apalis iMX6, Colibri VF: deploy imx loader | Max Krummenacher | |
- build and deploy imx_usb, imx_uart - currently it builds for the build host arch, i.e x86-64 or i386 | |||
2014-04-01 | u-boot: convert bbappend to a bb | Max Krummenacher | |
2014-04-01 | u-boot: add Apalis iMX6 and Colibri VF recipe | Max Krummenacher | |
2014-04-01 | kernel: add Apalis iMX6 and Colibri VF recipe | Max Krummenacher | |
2014-04-01 | images: add Apalis iMX6 | Max Krummenacher | |
2014-04-01 | angstrom-qt-x11-image: add gstreamer jpeg plugin | Max Krummenacher | |
2014-04-01 | images: add e2fsprogs to eMMC modules, fstrim | Max Krummenacher | |
2014-04-01 | util-linux bbappend: update to match bb version | Max Krummenacher | |
2014-04-01 | base-files: add iMX6 specific files | Max Krummenacher | |
2014-04-01 | glmark2: make sure libpng V1.2 and gles is installed | Max Krummenacher | |
2014-04-01 | gpioconfig: make the executable SOC family specific | Max Krummenacher | |
2014-04-01 | trdx-image-fstype: add u-boot extension for iMX6 | Max Krummenacher | |
