Related to: #49287
The Wi-Fi drivers from kernel 4.14 provide all needed features. So don't
bother with backports.
While at it move all Wi-Fi related packages into the Wi-Fi variables.
We want to choose different display managers for different image
recipes. Thus do not inject one through this packagegroup.
The gpio-tool recipe declares all binaries as stripped. The packages qa check
fails now if the binaries are not stripped as follows:
| ERROR: gpio-tool-1.0-r3 do_package: QA Issue: gpio-tool: Files/directories were installed but not shipped in any package:
| /usr/bin/.debug
| /usr/bin/.debug/gpio-tool
| Please set FILES such that these items are packaged. Alternatively if they are unneeded, avoid installing them or delete them within do_install.
| gpio-tool: 2 installed and not shipped files. [installed-vs-shipped]
The service expects the script to return (Type=forking). Change the script
so that the wayland app is started in the background.
While at it configure the service to restart the application.
Include a launcher for the weston-terminal if built for wayland/xwayland.
Rework that the X11 launcher is only used if not using xwayland.
This tries to start a wayland application after weston got started.
Create a copy of wayland-terminal-launch_1.0.bb with the variables
changed according to your needs.
RDEPENDS is set by bitbake to an empty string, so using ?= is pointless.
This reduces the binary from 400 to 4k.
packagegroup-base-extended is installed by inheriting core-image.
packagegroup-basic installs dropbear, openssh-sftp, openssh-sftp-server
dropbear can act as an scp client, drop openssh-scp
Define the string used for each machine in the machine configuration
rather than doing this in each image recipe.
Fallback to machine configuration name if not defined.
We used to do this in the dropped tdx-image-fstype.inc.
If a build is configured for a wayland or xwayland graphical backend
install an sample application too.
Without this xinit fails because /usr/bin/x-window-manager does not exist
and systemd then indefinitely retries to start X11.
This recipe starts xterm as the first X11 application.
Pull out common code so that the bb file only contains information about
the application which is to be started.
Rename the recipe so that one knows what is going to be started.
populate_sdk_qt5"
This reverts commit 0af5df0bd71d1714c1b2623fd9f6d57619926278.
meta_qt5 got fixed so that it is no longer needed to force an inherit order.
This prevents that with every build of the image the sdk is also built.
Also apply the same to lxqt-image.
Import from meta-fsl-bsp-release @ sumo-4.14.78-1.0.0_ga
Qt 4 was first released in 2005 and has been unsupported since 2015.
Drop it from what we regularly install.
This is a follow-up to:
e1026cf43 images: do not explicitely install ${XSERVER}
(cherry picked from commit 832e3954f29df6ce1f5cc385ebefa2ef7f27ebd0)
(cherry picked from commit 2bba608252c7c09447e94bbacf8b1310113b12ff)
This among others installs modeprint, modetest.
We decided we won't do a BSP 3.0 for Vybrid.
For new designs we recommend ULL now.
Use the Toradex Easy Installer instead.
If you included tdx-image-fstype.inc in your image recipes you will have
to remove that include.
This is added through distro features settings.
No change in what gets installed intendend.
This among others provides taskset.
can-utils support CAN-FD which canutils does not.
Variables from tdx_version.conf are now provided by the distro.
Add defaults in case someone uses tdx-image-fstype without our distro.
All of meta-toradex-tegra contains now all needed for TK1.
Drop meta-jetson-tk1.
Without gphoto libusb is otherwise not available and configure fails.
meta-oe now provides libpwquality. Drop the recipe here.
The backports recipe does not yet work with the kernel used for
apalis-imx8 and colibri-imx8qxp.
gstreamer1.0-libav needs commercial licenses to be whitelisted,
thus only install it when this is allowed through configuration.
E.g. add
LICENSE_FLAGS_WHITELIST = "commercial_gstreamer1.0-libav" to local.conf
to allow installing libav.
The backports configuration does not match the kernel used.
Angstrom sets this in the distro configuration, poky does not.
So enable it in local.conf to get the usefull debug aid build/buildhistroy.
