Update to latest version (SVN r671) of burnflash.
Update to latest version (r663) of Vybrid flash scripts.
PublicDomain is not known to OE
Pull out common files of the module specific trees into the common library
directory and symlink the files.
Drop the burnflash.tar.bz2 tarball and put the individual files under
version control.
Only create minimal set for colibri-t20 for now and move it with the
change to tegra-uboot-flasher.
Neiter graphviz_2.32.0.bb graphviz_2.38.0.bb work with dizzy.
Uses python directory from build host.
The SUMMARY variable gives a short description of the package (<72 chars).
A missing DESCRIPTION is automatically set to the content of SUMMARY.
${PN} might be extended with some magic prefix, so don't use it in SRC_URI
assignments et. al.
There is no difference between iMX6 / Tegra based modules
remove consistent_defconfig_dirs.patch as it is no longer needed
starting with 0.5.6
consistent_defconfig_dirs.patch is no longer needed.
change bbappend to contain % instead of the version
Add the lxde components with meta-lxde packagegroups
and the window and display manager here.
Don't explicitely add packages already added by the lxde package group.
Mechanism changed to what the bb file now offers.
While at it move version to % placeholder and use wildcards in receipe
icu: use wildcard to be independent of version
The default changed to zImage so explicit set uImage for now.
While at it cleanup the recipe, remove pci from Colibri machine features.
compiling gvfs with samba support in dizzy does not only pull in smbclient
but the full samba package, i.e. 50MB+.
gnutls recipe now detects pthread in configure task correctly.
While at it replace Tegra machines with SOC family
recipes-qt/qt4/qt4-x11-free_4.8.5.bbappend
Update to top of -next branch which also includes FEC unbind
fixes.
- Make sure leases file is not persistent (in /var/run now)
This allows to serve the same IP to the generated (and hence
different IP addresses)
- Start RNDIS service after the network.target
- Tegra: Add extra service for udhcpd. When running dhcpd directly
from udev, the daemon will be killed after a while
meta-angstrom now overrides the effect of the patch and provides the
journald.conffile in full.
To override a setting either create the file with your settings in
meta-toradex/recipes-core/systemd/systemd/journald.conf or
edit meta-angstrom/recipes-core/systemd/systemd/journald.conf.
Convert qt-demo-init to a systemd service. The service will only
start when the systemd target is set to graphical, hence also set
the new default target of the qt4e-demo-image to graphical.
Add a recipe for the Chromium OS version of the mmc-utils able to
handle Extended CSD revision 1.7 of the latest MMC 5.0 specification.
Some of the more interesting information thereof is the life time
estimation and pre EOL information as follows:
root@apalis-t30:~# mmc extcsd read /dev/mmcblk0 | \
grep -A 3 'Device life time estimation type A'
Device life time estimation type A [DEVICE_LIFE_TIME_EST_TYP_A: 0x01]
i.e. 0% - 10% device life time used
Pre EOL information [PRE_EOL_INFO: 0x01]
i.e. Normal
Add issue with getty also started on ttymxc1.
Also update default defconfig for colibri-vf.
This patch fixes the issue of getting serial tty login at ttymxc1 (UART_B).
Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
Remove debug feed URL as it does not exist.
Re-add Colibri T20 specific (ARM, hard-float, non-neon) feeds which
recently are built in Angstrom again as Atmel SAMA5D3 is non-neon as
well.
The IT variant needs different RAM timings
