2013-10-14 | cortex-a5.inc: backport from openembedded-core dora branch | Max Krummenacher | |
revert when moving to dora | |||
2013-10-11 | images: add a qt4 embedded image | Max Krummenacher | |
still missing automatic start of a demo (and detecting keyboard, mouse, touch) export QWS_DISPLAY="LinuxFb:/dev/fb:depth=24" export QWS_KEYBOARD="USB:/dev/input/event1" export QWS_MOUSE_PROTO="LinuxInput:/dev/input/event2" qtdemoE -qws | |||
2013-10-11 | qt4-embedded: configure with -depths generic | Max Krummenacher | |
2013-10-11 | icu: replace database with minimzed version | Max Krummenacher | |
2013-10-11 | feed-config: remove non working feeds, add feeds for T30 VF50 | Max Krummenacher | |
- remove links to incompatible architecture feeds - for Colibri T30, Apalis T30 and Colibri VF50 there are compatible feeds - for Colibri T20 there are no compatible feeds | |||
2013-10-11 | console-image: fix the inclusion of X11 | Max Krummenacher | |
2013-10-10 | colibri-vf50: add the machine, kernel and u-boot | Max Krummenacher | |
- also add the relevant configuration files | |||
2013-10-10 | conf: update sample configuration | Max Krummenacher | |
2013-10-10 | image-fstype: add colibri-vfxx module | Max Krummenacher | |
2013-10-10 | images: cleanup, add colibri-vfxx module | Max Krummenacher | |
- Add optimizations needed for the Colibri VFxx modules - Move common stuff to trdx-extra.inc, /etc/timestamp, CAN utils - Cleanup whitespace and commented stuff - Split out gstreamer packages, don't add them on Colibri VFxx angstrom-lxde-image: - Browser for Colibri VFxx is midori for size reasons console-image: - don't add X11 for Colibri VFxx | |||
2013-10-10 | u-boot-fw-utils: add bbappend to use the same u-boot sources | Max Krummenacher | |
2013-10-09 | i2c-tools: don't install the perl scripts (and thus don't RDEPEND on perl) | Max Krummenacher | |
2013-10-07 | u-boot: clean up recipe | Max Krummenacher | |
2013-09-22 | gdk-pixbuf: change to the new X11DEPENDS for override | Max Krummenacher | |
2013-09-22 | florence: RDEPEND on svg support to draw icon | Max Krummenacher | |
2013-09-22 | images: use consistent image names | Max Krummenacher | |
- use consistent image names - while at it build the GLES samples only for a tegra machine | |||
2013-09-22 | image: add handling for imx u-boot extension | Max Krummenacher | |
2013-09-22 | image: add update-alternative and ethtool | Max Krummenacher | |
2013-09-22 | dropbear: fix moved path to sftp server | Max Krummenacher | |
2013-09-22 | wpa-supplicant: workaround missing service file | Max Krummenacher | |
2013-09-22 | v4l2-utils: removed patch, fixed upstream now | Max Krummenacher | |
2013-09-22 | openssh: follow update of recipe with bbappend | Max Krummenacher | |
2013-09-22 | hda-verb: add recipe | Max Krummenacher | |
HDA debug tool | |||
2013-09-22 | codecgraph: add recipe | Max Krummenacher | |
2013-09-22 | graphviz: add recipe | Max Krummenacher | |
2013-09-22 | systemd: systemd bbappend update to version 199 | Max Krummenacher | |
2013-09-22 | lxdm: path to greeter changed, adapt conf file | Max Krummenacher | |
2013-09-22 | connman: add commandline configuration tool | Max Krummenacher | |
root@colibri-t30:~# connmanctl connmanctl> services *AO Wired { ethernet_00142d259a48_cable } connmanctl> services ethernet_00142d259a48_cable [ ethernet_00142d259a48_cable ] Type = ethernet Security = [ ] State = online Favorite = True Immutable = False AutoConnect = True Name = Wired Ethernet = { Method=auto Interface=eth0 Address=00:14:2D:25:9A:48 MTU=1500 } IPv4 = { Method=dhcp Address=192.168.10.2 Netmask=255.255.255.0 Gateway=192.168.10.1 } IPv4.Configuration = { Method=dhcp } IPv6 = { } IPv6.Configuration = { Method=auto Privacy=disabled } Nameservers = [ 192.168.0.32 ] Nameservers.Configuration = [ ] Timeservers = [ 192.168.0.32 ] Timeservers.Configuration = [ ] Domains = [ ] Domains.Configuration = [ ] Proxy = { Method=direct } Proxy.Configuration = { } Provider = { } connmanctl> config ethernet_00142d259a48_cable --ipv4 manual 192.168.10.2 255.255.255.0 192.168.10.1 connmanctl> exit root@colibri-t30:~# connmanctl connmanctl> config ethernet_00142d259a48_cable --ipv4 dhcp connmanctl> exit | |||
2013-09-22 | inhibit missing debug info warnings in binary package | Max Krummenacher | |
2013-09-22 | lxlauncher: fix FILES variable | Max Krummenacher | |
2013-09-22 | systemd: adapt to new systemd handling | Max Krummenacher | |
with the move from meta-openembedded to oe-core some things have changed, e.g. the config files have to explicitly installed | |||
2013-09-22 | mediainfo: dont hardcode build architecture | Max Krummenacher | |
2013-09-22 | stress: correct license text | Max Krummenacher | |
remove backup file while at it | |||
2013-09-22 | local.conf template: add inclusion of license information | Max Krummenacher | |
2013-09-22 | lxde: use renamed recipe packagegroup* recipe | Max Krummenacher | |
2013-09-22 | u-boot: don't build the examples | Max Krummenacher | |
- they do fail because they don't heed the private libgcc | |||
2013-09-22 | remove obsolete files | Max Krummenacher | |
2013-09-22 | qt4: follow update of recipe with bbappend | Max Krummenacher | |
2013-09-22 | systemd: follow update of recipe with bbappend | Max Krummenacher | |
2013-09-22 | wpa-supplicant: don't install systemd service file | Max Krummenacher | |
- is already installed | |||
2013-09-22 | x-server: add version 1.13.1 which is removed from core | Max Krummenacher | |
2013-09-22 | linux-firmware_git: remove bbappend, recipe now more granular | Max Krummenacher | |
2013-09-22 | libxi: provide dummy recipe - libxi.bbappend in a layer breaks build | Max Krummenacher | |
2013-09-22 | lxappearance-obconf: update to 0.2.0 | Max Krummenacher | |
2013-09-22 | gstreamer: make sure plugin package gets generated, disable sdl | Max Krummenacher | |
2013-09-22 | connman: add a unused .bb to silence a bbappend | Max Krummenacher | |
2013-09-22 | firefox: updated to 10.0.11esr | Max Krummenacher | |
2013-09-22 | python-numpy: bbappend deleted, now fixed in openembedded layer | Max Krummenacher | |
2013-09-22 | libfm: bbappend updated to 1.1 | Max Krummenacher | |
2013-09-22 | connman: bbappend updated to 1.12 | Max Krummenacher | |
