Unfortunately, our bbappend broke execution of the ontarget postinst
scripts as the following openembedded-core commit changed the way this
works upstream.
1af421fcf054
("run-postinsts: for dpkg/opkg, do not rely on /etc/*-postinsts")
Just get rid of our bbappend and rely on properly working upstream.
(cherry picked from commit ff479c129366b7f67945e661472762ae6cb541f2)
This adds the Bluetooth UART initialisation as required for the Verdin
iMX8M Plus 4GB WB IT V1.1A.
(cherry picked from commit 7df50f3ff17aa4ce839dee8a38f14844460ac819)
This adds the Wi-Fi/Bluetooth firmware as required for the Verdin iMX8M
(cherry picked from commit c67b830a4f768d6507949bfcdff2f8c7b60a8f5e)
There is now a 'weston' image feature introduced in OE, we can use it
to install weston related packages and choose SYSTEMD_DEFAULT_TARGET.
Also change to use "x11-base" image feature instead of "x11", this
ensures x11 init scripts would be installed to image.
Related-to: ELB-3477
Signed-off-by: Ming Liu <ming.liu@toradex.com>
It's been handled in weston-init recipe of meta-toradex-nxp layer, drop
a duplicated weston env file.
Since OE-Core commit 9379f80f48 ("license/insane: Show warning for
obsolete license usage"), LICENSE field not containing SPDX identifiers
are treated with WARNING.
An automated conversion using scripts/contrib/convert-spdx-licenses.py to
convert to use the standard SPDX license identifiers has been done on
the entire layer.
Follow meta-freescale commit 30f5ce1d ("Generalize overrides subsystem for
NXP and Mainline support").
PREMIRRORS is a variable, use the correct syntax.
Prevents:
| WARNING: Invalid mirror variable value for PREMIRRORS: ['bzr://.*/.*', 'https://downloads.yoctoproject.org/mirror/sources/', ...], should contain paired members.
Disable background scan in config to avoid a significant increase in
bandwidth.
Related-to: ELB-4148
Disable BackgroundScan in main.conf.
(cherry picked from commit 097df183d8e70cfcf4267425c195a6dcfcdbc9ed)
- Drop 0001-connman.service.in-don-t-start-if-nfs-boot.patch, since
commit "ef0d26e6: rootnfs: Working rootnfs using connman", connman
can handle nfs rootfs on NICs.
- Change "+=" to "_append", this could avoid some cases "+=" being
overridden by overrides variables.
(cherry picked from commit fd7a7b83175368f809b237979e3f20304a5571de)
TEZI_SHOW_EULA_LICENSE shall be a machine global variable but not image
specific, move it to tdx-base.inc in meta-toradex-distro layer.
Torizoncore/Tezi/BSP now use the same setting of
TEZI_SHOW_EULA_LICENSE.
Related-to: TOR-2102
(cherry picked from commit 95a04d675063b714504ccc9d38f6ea71244f64e4)
Since commit c39452bf65 ("curl: Use openssl backend") openembedded core
uses openssl by default.
On top of that the package config name changed recently from ssl to
openssl resulting in a warning.
Just drop the bbappend.
openembedded-core, commit 5bf3e447d2 ("package: Add sanity check for
allarch packagegroups") added a check which now emits an error.
Fix that.
| ERROR: packagegroup-dotnet-core-1.0-r0 do_package_write_ipk: An allarch packagegroup shouldn't depend on packages which are dynamically renamed (libcurl to libcurl4)
OE master will soon require setting a branch, i.e. no longer defaulting
to master. Prepare for that.
| WARNING: clpeak-git-r0 do_fetch: URL: git://github.com/krrishnarraj/clpeak.git;protocol=https does not set any branch parameter. The future default branch used by tools and repositories is uncertain and we will therefore soon require this is set in all git urls.
Add fio, Flexible I/O tester [*], to devel-tdx-cli package group, the
tool is useful for benchmark and hardware verification of I/O subsystem
and hardware devices.
tdx-reference-multimedia-image rootfs size increase is 1124k after the
inclusion.
[*] https://fio.readthedocs.io/
Related-to: ELB-4213
Signed-off-by: Francesco Dolcini <francesco.dolcini@toradex.com>
(cherry picked from commit c369af47314e1b1e1776dcfa0cee1befc73fd044)
This is the result of automated script (0.9.3) conversion:
+# meta-toradex-distro
+vars = vars + ["preempt-rt","tdx","upstream"]
+# meta-toradex-* machines
+vars = vars + ["apalis-","colibri-","verdin-","tegra124"]
+# meta-freescale
+vars = vars + ["imx","mx6","mx7","mx8","use-mainline-bsp","use-nxp-bsp"]
../openembedded-core/scripts/contrib/convert-overrides.py .
converting the metadata to use ":" as the override character instead of "_".
(cherry picked from commit f99619b2135ff939b6370be8116d66a10bc84836)
This was needed for the update scripts for the colibri-vf machine. The
machine got dropped, so drop this bbappend also.
NXP provides proprietary VPU libraries with media codecs for i.MX6
Toradex Easy Installer customer has to accept EULA for i.MX6 builds
Related-to: ELB-3945
Signed-off-by: Denys Drozdov <denys.drozdov@toradex.com>
(cherry picked from commit edb69bd5c57c0bc65558eca01553df6c433bd194)
The systemd service set-hostname starts only if /etc/hostname
file does not exist. Don't install this file if the set-hostname
recipe enabled and systemd sets as a default init-system.
Related-to: ELB-1322
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
(cherry picked from commit 2b41160a098d5cc1ad3e5155e57bede7ce34ca48)
The service "set-hostname" adds a serial number of a module to a
machine hostname. It allows a customer to identify a module he
is working with simply.
Add it to the "packagegroup-base-tdx-cli", so that all Reference
Multimedia and Minimal images have hostnames like Torizon in the
style of "colibri-imx8x-06748675". Also, customers using the
"packagegroup-base-tdx-cli" inherit that and it lands in their
production image.
(cherry picked from commit c00e37b6324b16361ddc08abfdf39acd54d60ce6)
Tezi will not show EULA License for Apalis TK1 and upstream builds
(cherry picked from commit 49d49b87cb98e061731e38985b425147e22dcfcb)
With the 4.4 kernel perf no longer builds. Don't add it to the
packagegroup for colibri-vf machine with use-nxp-bsp.
(cherry picked from commit bf5691c4651ece15e6b08e9fc347b657dd9af38b)
(cherry picked from commit 9c277f8bf4fa3c6a0b2c10c93b66b28f440d9723)
All others can/will use the generic recipe now available at
meta-openembedded/meta-oe/recipes-kernel/spidev-test/spidev-test.bb
Cater for updated license file.
Fixes: openembedded-core commit 5ecf139a31fa
("licenses: Update license file to match current SPDX names")
This reverts commit 8b6a847c7cd879f2d77452321eae3e0f5d8c6b41.
This adds packages related to the i.MX 8M Plus ISP (Image signal processor).
For all other machines this packegroup does currently doesn't add anything.
Related-to: ELB-3957
(cherry picked from commit b7ed660510e95eb50c707153a5c3713c0338135c)
Related-to: ELB-3908
(cherry picked from commit 08f3c7a36539dbe2760e0500c7c460dbcd48be4d)
Note that later versions of dropbear default to not do reverse lookups.
(cherry picked from commit ee43d6a6132bbd45696586fac1f68f5af32d5687)
Sources from TorizonCore and BSP are aggregated on new artifactory repository
https://artifacts.toradex.com/artifactory/tdxref-torizoncore-sources-frankfurt/
Use this new link plus $TDX_MAJOR to use the correct sources for the current
major version
(cherry picked from commit 709b72950c5406ef0e511fee7030b51fc8681e14)
The user running ssh session should be able
to run wayland application. Add proper XDG settings,
once user logged in /etc/profile.d/wayland-env.sh
Related-to: ELB-3448
(cherry picked from commit 82e3d7b2b56fccabcd52708314acc9dfd6bb24d1)
In BSP V2.x we used to provide release notes in a text file. These are
now outdated. Delete them.
For the current BSP the equivalent info can be found here:
https://developer.toradex.com/software/linux/linux-software/release-details
(cherry picked from commit 3384ba4a86592d6095b06355544e00ebc2996654)
Related-to: ELB-3478
(cherry picked from commit bda9e7f561b50cda6881d0300f9c0d4f93fd9549)
Mount the partition /dev/boot-part on /boot.
This requires the help of udev/scripts/mount.sh. The script checks
the /proc/cmdline for the rootfs partition. If this is the second
partition of a block device and a first partition exists it creates
the symlink /dev/boot-part.
This reverts the previous mounting scheme which unconditionally mounted
the first eMMC partition at /boot, independent of the eMMC being the
actual device one booted from. commit 38705bd ("fstab: configure
the emmc's first partition to mount at /boot")
Related-to: ELB-3323
(cherry picked from commit 3bb042fc4cf0254ca9630b43a3f604176c540aaf)
Follow the following two oe-core commits with our forked fstab file.
c999bc5ddd ("base-files: set ptmxmode to 666")
c24f0fa366 ("base-files: Remove /proc/bus/usb from fstab.")
(cherry picked from commit 9c5431a22bb2e7b31280642ba866e9aec6a52b75)
Tezi will show EULA License for Toradex reference targets.
Related-to: ELB-3485
(cherry picked from commit db7776dd7e6eae80811568b85bbf478e35f27045)
This helps people which can't access the web with the git protocol.
Related-to: ELB-3475
(cherry picked from commit bf1bc67f2de9f0245da66a3a15d5c439ee7462d7)
(cherry picked from commit 591e318f80d31694203bec4267e285ad90e5c3af)
This was never part of one of our regular images.
hda-verb is now built as part of the alsa-tools recipe and packaged
into the alsa-tools package.
(cherry picked from commit 5026458289e8bf0d60981bcf647723419a940d1b)
Fix dependencies to prevent a possible race which provokes the
following build failure:
| WARNING: spidev-test-1.0-r0 do_populate_lic: Could not copy license file ...work-shared/colibri-imx8x/kernel-source/tools/spi/spidev_test.c ... [Errno 2] No such file or directory:
| ERROR: spidev-test-1.0-r0 do_populate_lic: QA Issue: spidev-test: LIC_FILES_CHKSUM points to an invalid file
Commit 8b6a847 ("spidev-test: drop support for older kernel and change
license check") checks the license from the shared kernel sources.
Make sure that these are available before accessing those files.
The source file in the kernel moved with kernel 4.5. Drop support
for older kernels.
Upstream commit 2456f523cf ("licenses: Update license file to match
current SPDX names") deprecated the usage of GPL-2.0 SPDX identifier,
removed GPL-2.0 license file and replaced it with GPL-2.0-only SPDX
identifier and text file.
Rather than pointing to the new generic file rework to check the license
from the SPDX header in the source file.
With the noauto option this does nothing on boot. When the device appears
the udev rules does first try to use the fstab options before trying
to automount.
If the device does not exist the extra line in fstab has no effect.
Related-to: ELB-3250
(cherry picked from commit 38705bdc1ff671597680c5a9c9d1a76822bb5620)
Provide a higher ranking video sink plugin than the not working
imxeglvivsink and thus fixes automatic (playbin) pipeline construction
and audio mpeg codec warning (AAC codec).
Additionaly include a NXP userspace cli tool to play or record with
gstreamer.
Related-to: ELB-3013
Related-to: ELB-3010
Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
(cherry picked from commit 62a138575743b9780aff969c041432194680d4c3)
(cherry picked from commit 07a1a12d2487df6175da53644f645ed156e0ca06)
