2015-01-14 | qt4-x11-free: append to DEPENDS, not overwrite it | Max Krummenacher | |
2015-01-13 | Apalis iMX6: Update release notes for Beta6 | Max Krummenacher | |
2015-01-12 | feeds: remove debug and re-add hard-float non-neon feeds | Marcel Ziswiler | |
Remove debug feed URL as it does not exist. Re-add Colibri T20 specific (ARM, hard-float, non-neon) feeds which recently are built in Angstrom again as Atmel SAMA5D3 is non-neon as well. | |||
2015-01-09 | u-boot: build additional binary for Apalis iMX6Q 2GB IT | Max Krummenacher | |
The IT variant needs different RAM timings | |||
2015-01-09 | Apalis iMX6: Update release notes | Max Krummenacher | |
2015-01-09 | rdesktop: add rdesktop recipe | Marcel Ziswiler | |
2014-12-19 | Apalis/Colibri iMX6/T20/T30/VF50/VF61: Update release notes | Marcel Ziswiler | |
2014-12-19 | Apalis iMX6/T30 & Colibri T20/T30/VF50/VF61: fix GPIOConfig | Marcel Ziswiler | |
2014-12-19 | colibri-imx6: add u-boot-fw-utils | Max Krummenacher | |
2014-12-19 | u-boot/u-boot-fw-utils: update all to latest | Max Krummenacher | |
2014-12-19 | colibri_vf: update U-Boot and Linux kernel git hashes | Stefan Agner | |
Two last minute fixes: Default Product/Vendor ID for USB peripheral in U-Boot and fix for the USB peripheral RNDIS freeze. | |||
2014-12-18 | Update all to latest and greatest U-Boot and Linux kernel. | Marcel Ziswiler | |
2014-12-18 | GPIOConfig: update with mainline kernel support | Stefan Agner | |
2014-12-18 | mcc-pingpong: alter CFLAGS to use the actual kernel headers | Stefan Agner | |
To use the kernel interfaces required for mcc-pingpong we need the kernel headers of the actual kernel. Alter CFLAGS to add the kernel headers to the include path. | |||
2014-12-18 | trdx-extra.inc: ensure machine-id is non volatile | Max Krummenacher | |
If the rootfs in early init is read-only /etc/machine-id is in a tempfs. systemd-machine-id-commit can be used to migrate to the 'real' rootfs. The command is run in the installers postinst and thus needs no further activation. | |||
2014-12-18 | systemd-machine-id-commit: add standalone recipe | Max Krummenacher | |
2014-12-18 | mcc-kmod: use mcc kernel module from toradex git | Stefan Agner | |
In order to make the MCC kernel module working with our newer kernel some changes had been made on the MCC kernel module. The changes are available on the Toradex Github account. Get the MCC kernel module sources from Github. | |||
2014-12-16 | colibri-vf: switch to mainline kernel based on 3.18 | Stefan Agner | |
Switch default kernel recipe to linux-toradex-vf which will build a kernel based on the toradex 3.18-next branch. | |||
2014-12-11 | colibri-vf: update Kernel | Max Krummenacher | |
2014-12-11 | colibri-vf: update U-Boot | Max Krummenacher | |
2014-12-11 | apalis/colibri-imx6: U-Boot and Kernel for V1.0/V1.1 | Max Krummenacher | |
Update to a U-Boot and Kernel which can be used for Apalis iMX6 HW version V1.0 and V1.1. Also deploy additional device tree for Apalis iMX6 V1.0 modules | |||
2014-12-11 | qt4e-demo-image: remove xdg-utils | Max Krummenacher | |
xdg-utils pulls in at least part of the X server. | |||
2014-12-11 | consolekit: add systemd to DEPENDS if needed | Max Krummenacher | |
2014-12-11 | samba: add quota to the DEPENDS | Max Krummenacher | |
2014-12-08 | Colibri iMX6: Update release notes | Max Krummenacher | |
Add update of single component U-Boot/Kernel/FDT Remove unavailable interfaces from the list of notworking Add correct git tag | |||
2014-12-08 | Release Notes: fix changed URL | Max Krummenacher | |
While at it remove supperseeded release note | |||
2014-12-08 | Colibri iMX6/T30: Add/Update release notes | Max Krummenacher | |
Add inital release notes for Colibri iMX6 Fix Colibri T30, EvalBoard MMC connector designator | |||
2014-12-08 | Apalis/Colibri T30: Update release notes | Max Krummenacher | |
Workaround for resize script | |||
2014-12-08 | qt4-x11-free-systemd.bb: move init script to /usr/bin | Stefan Agner | |
Due to the move to systemd, all init scripts located under /etc/init.d get deleted by the inherited systemd recipes (systemd.inc). Since we don't use the script as a system V init script, we can move the script to /usr/bin. | |||
2014-12-08 | qt4 bbappend: add dependencies to OpenGL ES2 | Stefan Agner | |
Since we explicitly ask to build Qt for OpenGL ES2, we should also make OpenGL ES2 as a explicit dependency. | |||
2014-12-08 | apalis/colibri imx6/t20/t30: deploy eglinfo-x11 | Marcel Ziswiler | |
2014-11-13 | apalis/colibri_imx6: get rid of imx_usb.m32 | Marcel Ziswiler | |
2014-11-13 | Apalis/Colibri iMX6/T20/T30/VF50/VF61: rev kernel version to V2.3b4 | Marcel Ziswiler | |
2014-11-13 | Apalis/Colibri iMX6/T20/T30/VF50/VF61: Update release notes | Marcel Ziswiler | |
2014-11-13 | apalis/colibri_imx6: fix wallpaper | Marcel Ziswiler | |
2014-11-13 | apalis/colibri_t30: fix fw_setenv | Marcel Ziswiler | |
2014-11-13 | Apalis iMX6/T30 & Colibri T20/T30/VF50/VF61: update resp. introduce ↵ | Marcel Ziswiler | |
GPIOconfig tool | |||
2014-11-13 | colibri-vf: add mainline kernel recipe | Stefan Agner | |
Add recipe to build mainline kernel. Currently, the 3.17 next branch will be built. To use this kernel, add this lines to your local.conf PREFERRED_PROVIDER_virtual/kernel ?= "linux-toradex" IMAGE_INSTALL_append = "kernel-devicetree" KERNEL_DEVICETREE += "vf500-colibri-eval-v3.dtb vf610-colibri-eval-v3.dtb" Also, the multi-core communication packages (mqxboot, libmcc, mcc-pingpong and kernel-module-mcc) need to be removed from recipes/images/trdx-extra.inc since the required kernel interfaces are not available on the 3.17 mainline port. | |||
2014-11-05 | Apalis/Colibri iMX6/T20/T30/VF50/VF61: Update release notes | Marcel Ziswiler | |
2014-11-03 | Apalis/Colibri T30: Fixed release notes | Marcel Ziswiler | |
Got the U-Boot stuff mixed up. | |||
2014-11-03 | Apalis/Colibri iMX6/T20/T30/VF50/VF61: Update release notes | Marcel Ziswiler | |
2014-10-31 | xserver-common_%.bbappend: don't start XDG autostart | Max Krummenacher | |
This is also done by the session manager effectively starting the autostart items twice. | |||
2014-10-31 | trdx-extra.inc: deploy fw_printenv also on T30 | Max Krummenacher | |
2014-10-30 | machine: imx6: fix thumb2 arch setting | Max Krummenacher | |
2014-10-30 | colibri-imx6: add machine definition and burnflash | Max Krummenacher | |
2014-10-30 | machines: use thumb2 with meta-angstrom | Max Krummenacher | |
Angstrom started using thumb2 on machines with armv7-a architectures. This commit removes our override to stay on arm instruction set, so if building our machines with the angstrom distribution you now get thumb2 builds. | |||
2014-10-30 | u-boot: iMX6/VF update to latest from git | Max Krummenacher | |
2014-10-30 | linux: iMX6/VF update to latest from git | Max Krummenacher | |
2014-10-30 | timestamp-service: remove in favor of meta-angstrom patch | Max Krummenacher | |
2014-10-30 | apalis/colibri_t30: latest u-boot git migrated to cbootimage/tegrarcm | Marcel Ziswiler | |
Use latest U-Boot from git. Migrate to using cbootimage and tegrarcm. |
