2016-06-30 | buildconf/bblayers.conf: integrate watatuki's meta-jetson-tk1 | Marcel Ziswiler | |
Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com> | |||
2016-03-14 | local.conf: add colibri-imx7 | Stefan Agner | |
Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com> | |||
2016-03-14 | bblayers.conf: angstrom now depends on meta-qt5 | Max Krummenacher | |
meta-angstrom unconditionally includes stuff from meta-qt5. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com> | |||
2016-03-14 | local.conf: adopt DISTRO to jethro | Max Krummenacher | |
2016-03-14 | bblayers.conf: drop unused layer | Max Krummenacher | |
2015-11-04 | local.conf: enable USB CDC ACM console for Vybrid based devices | Stefan Agner | |
The Vybrid devices use a composite gadget device by default which offers a serial connection over USB on the USB peripheral port. This enables a serial console on that tty. | |||
2015-11-03 | local.conf: add Toradex source mirror as pre-mirror | Stefan Agner | |
To download the sources mirrored on sources.toradex.com add the Toradex mirror as pre-mirror. | |||
2015-10-30 | local.conf: List Toradex machines explicitly | Stefan Agner | |
List all Toradex machines explicitly while still selecting Colibri T20 by default. Move selection of Qemu targets after our machines. | |||
2015-10-30 | build: add list of Toradex images | Stefan Agner | |
2015-08-18 | local.conf: adopt DISTRO to fido and drop PREFERRED_PROVIDER_glibc | Marcel Ziswiler | |
2015-05-12 | local.conf: update PREFERRED_PROVIDER for libc | Stefan Agner | |
eglibc has been superseded by glibc. Update the PREFERRED_PROVIDER to use set the preferred provider of glibc. | |||
2015-05-12 | bblayers: add meta-python which is required for dizzy now | Max Krummenacher | |
2015-05-12 | local.conf: update the distro version to its dizzy value | Max Krummenacher | |
2014-08-04 | local.conf: update sample local.conf | Max Krummenacher | |
2014-04-04 | bblayers.conf: add new required layers to defaults | Max Krummenacher | |
2014-04-01 | local.conf: update default local.conf | Max Krummenacher | |
- include package-management metadata in image - update distro to angstrom-v2013.12 | |||
2013-10-16 | build: fix cp destination in sample script | Max Krummenacher | |
2013-10-16 | build: add a sample script for setting up the environment | Max Krummenacher | |
2013-10-16 | local.conf: set sensible defaults | Max Krummenacher | |
2013-10-16 | bblayers: remove unneeded layer | Max Krummenacher | |
2013-10-16 | bblayers.conf: change path to meta-lxde | Max Krummenacher | |
2013-10-10 | conf: update sample configuration | Max Krummenacher | |
2013-09-22 | local.conf template: add inclusion of license information | Max Krummenacher | |
2012-10-18 | config changes due to oe-core update | Max Krummenacher | |
2012-08-15 | L4T R15, oe-core Image V2.0Beta1 | Max Krummenacher | |
2012-07-19 | build configuration files | Max Krummenacher | |
