path: root/classes
2016-11-21update toradex-mirrors to V2.6Apalis_TK1_LinuxImageV2.6.1Beta2_20161122Stefan Agner
Update the URL of Toradex mirrors to the V2.6 subfolder. Unfortunately we missed that before doing the V2.6 release, hence most builds will try to fetch sources from V2.5. Therefor we synchronized all sources of V2.5 and V2.6 images into the V2.5 source folder and symlinked V2.6 to it. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-03-14toradex-mirrors.bbclass: drop support for svk sourcesMax Krummenacher
follow http://cgit.openembedded.org/openembedded-core/commit/meta/classes/mirrors.bbclass?id=9560d58596ceb50280b81296688883f3fca99aa6 This avoids: WARNING: Invalid protocol (svk) in PREMIRRORS: svk://.*/.* http://sources.toradex.com/V2.5/ Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2015-11-03local.conf: add Toradex source mirror as pre-mirrorStefan Agner
To download the sources mirrored on sources.toradex.com add the Toradex mirror as pre-mirror.
2014-04-01colibri-vf: use meta-fsl* layer for BSP filesMax Krummenacher
remove the files copied from meta-fsl* for Colibri-VF V2.1 move the colibri-vf u-boot and kernel stuff to meta-fsl-arm-extra
2013-10-16vybrid: backport from meta-fsl-arm master-nextMax Krummenacher
remove when moving to dora branch
