2013-10-16 | machines: T30 and VF50 consitstently use NEON and hard float | Max Krummenacher | |
- Colibri T30 and Apalis T30 changed to NEON - Colibri VF50 changed to hard float This makes packages built for T30 incompatible with Colibri T20 (but Colibri T20 packages can still be used on T30) | |||
2013-10-10 | colibri-vf50: add the machine, kernel and u-boot | Max Krummenacher | |
- also add the relevant configuration files |
