path: root/conf
2020-10-17.conf: Make layer compatible only with dunfell and gatesgarthMax Krummenacher
2020-03-29layer.conf: follow changed meta-freescale-distro nameMax Krummenacher
2020-03-21layer.conf: add dunfell, drop warrior in compat layerMax Krummenacher
2020-01-09README/layer.conf: update for master and no longer required layersMax Krummenacher
2020-01-09images: drop lxde-image, lxqt-image, qt5-x11-imageMax Krummenacher
As no image uses firefox, stop touching the recipe. Thus this layer no longer depends on meta-browser. As no image uses lxde, stop touching the recipes. Thus this layer no longer depends on meta-lxde. Related-to: ELB-1284 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-10-23layer.conf: add zeus, drop thud from compatible layersMax Krummenacher
2019-10-22layer.conf: add warrior, drop sumo from compatible layersMax Krummenacher
2019-05-08images and helpers: drop qt4Max Krummenacher
Qt 4 was first released in 2005 and has been unsupported since 2015. Drop it from what we regularly install. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-04-25conf/layer.conf: decrease layer priority to 24Max Krummenacher
2019-03-06distro: move from angstrom to a poky based distroMax Krummenacher
2019-03-06layer.conf: Add thud to LAYERSERIES_COMPATMax Krummenacher
2019-03-06layer: add LAYERSERIES_COMPATMax Krummenacher
2017-10-03qt5 toolchain: include python json module in the native sdkMax Krummenacher
As several customers reported qtcreator imports that python module when debugging. https://www.toradex.com/community/questions/11201/qt-creator-debugging-python-issue-colibri-imx7d.html Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-04-07layer.conf: add layer dependenciesMax Krummenacher
While at it clean-up and unify with other Toradex layers. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-09-28add layer.confMax Krummenacher
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2016-03-14Apalis/Colibri iMX6: drop in favour of meta-fsl-arm-extraMax Krummenacher
machine/u-boot/kernel files have been added to meta-fsl-arm-extra. Use them from there now. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2015-10-28machine Apalis iMX6: deploy Ixora device treesMax Krummenacher
2015-10-28machines iMX6: drop pinning of X-Server versionMax Krummenacher
2015-10-12Apalis iMX6: cleanup filename for V1.0 HWMax Krummenacher
Follow the rename imx6q-apalis-eval_v1_0.dtb to imx6q-apalis_v1_0-eval.dtb in the kernel. The v1_0 denotes the Apalis module version, not the evaluation board version.
2015-05-18machines: don't pin systemd version anymoreMax Krummenacher
Use systemd V2.18 from meta-angstrom. Issues with firmware loading and the 3.1.10 kernel for the tegra machines are fixed with a backport from oe-core.
2015-05-12Apalis/Colibri iMX6: kernel/U-Boot update to latest in -nextMax Krummenacher
Also deploy an additional device tree supporting a Colibri iMX6 with Analog Camera Module.
2015-05-12Apalis/Colibri iMX6 build kernel uImageMax Krummenacher
The default changed to zImage so explicit set uImage for now. While at it cleanup the recipe, remove pci from Colibri machine features.
2015-01-20apalis/colibri-imx6: Fix serial console ttyBhuvanChandra.DV
This patch fixes the issue of getting serial tty login at ttymxc1 (UART_B). Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
2014-12-11apalis/colibri-imx6: U-Boot and Kernel for V1.0/V1.1Max Krummenacher
Update to a U-Boot and Kernel which can be used for Apalis iMX6 HW version V1.0 and V1.1. Also deploy additional device tree for Apalis iMX6 V1.0 modules
2014-10-30machine: imx6: fix thumb2 arch settingMax Krummenacher
2014-10-30colibri-imx6: add machine definition and burnflashMax Krummenacher
2014-10-30machines: use thumb2 with meta-angstromMax Krummenacher
Angstrom started using thumb2 on machines with armv7-a architectures. This commit removes our override to stay on arm instruction set, so if building our machines with the angstrom distribution you now get thumb2 builds.
2014-10-06systemd: don't pull in systemd 216Max Krummenacher
meta-angstrom backported systemd 2.16 into daisy. Keep using 2.11 for now.
2014-08-04apalis-imx6.conf: specify the devicetree nameMax Krummenacher
2014-08-04machine.conf: xserver: make sure to use machine specificMax Krummenacher
If the package manager finds a version newer than the prefered-version that one gets installed. As we need a specific one for the tegras and for imx6 we change the 'epoch' to something very high.
2014-08-04machine.conf: unify MACHINE_FEATURESMax Krummenacher
unify the features between machines kernel26 is deprecated and unused apm does not make sense on ARM While at it remove some commented stuff
2014-06-12apalis-imx6: remove unneeded variableMax Krummenacher
2014-06-11virtual/kernel: set preferred unconditionalyMax Krummenacher
Be consistent with the other machine recipes Help the autobuilder setup
2014-04-04Revert "cortex-a5.inc: backport from openembedded-core dora branch"Max Krummenacher
File now provided by openembedded-core This reverts commit 592b1395c7cdff2125b5e42a7f9605749e625419.
2014-04-01machines: add colibri-vf, apalis-imx6Max Krummenacher
2014-04-01colibri-vf: use meta-fsl* layer for BSP filesMax Krummenacher
remove the files copied from meta-fsl* for Colibri-VF V2.1 move the colibri-vf u-boot and kernel stuff to meta-fsl-arm-extra
2013-11-21Machine: remove Colibri VF50, now unified with VF61Max Krummenacher
2013-11-21Vybrid: add 'vf' to SOC_FAMILYMax Krummenacher
2013-10-16machines: T30 and VF50 consitstently use NEON and hard floatMax Krummenacher
- Colibri T30 and Apalis T30 changed to NEON - Colibri VF50 changed to hard float This makes packages built for T30 incompatible with Colibri T20 (but Colibri T20 packages can still be used on T30)
2013-10-14vybrid: backport from meta-fsl-arm master-nextMax Krummenacher
remove when moving to dora branch
2013-10-14cortex-a5.inc: backport from openembedded-core dora branchMax Krummenacher
revert when moving to dora
2013-10-10colibri-vf50: add the machine, kernel and u-bootMax Krummenacher
- also add the relevant configuration files
2012-10-18removed *~ backup files from git repoMax Krummenacher
2012-07-21removed unneeded apmd from machine featuresMax Krummenacher
2012-06-03Initial commitMax Krummenacher
