2014-08-04 | machine.conf: unify MACHINE_FEATURES | Max Krummenacher | |
unify the features between machines kernel26 is deprecated and unused apm does not make sense on ARM While at it remove some commented stuff | |||
2014-06-12 | apalis-imx6: remove unneeded variable | Max Krummenacher | |
2014-06-11 | virtual/kernel: set preferred unconditionaly | Max Krummenacher | |
Be consistent with the other machine recipes Help the autobuilder setup | |||
2014-04-04 | Revert "cortex-a5.inc: backport from openembedded-core dora branch" | Max Krummenacher | |
File now provided by openembedded-core This reverts commit 592b1395c7cdff2125b5e42a7f9605749e625419. | |||
2014-04-01 | machines: add colibri-vf, apalis-imx6 | Max Krummenacher | |
2014-04-01 | colibri-vf: use meta-fsl* layer for BSP files | Max Krummenacher | |
remove the files copied from meta-fsl* for Colibri-VF V2.1 move the colibri-vf u-boot and kernel stuff to meta-fsl-arm-extra | |||
2013-11-21 | Machine: remove Colibri VF50, now unified with VF61 | Max Krummenacher | |
2013-11-21 | Vybrid: add 'vf' to SOC_FAMILY | Max Krummenacher | |
2013-10-16 | machines: T30 and VF50 consitstently use NEON and hard float | Max Krummenacher | |
- Colibri T30 and Apalis T30 changed to NEON - Colibri VF50 changed to hard float This makes packages built for T30 incompatible with Colibri T20 (but Colibri T20 packages can still be used on T30) | |||
2013-10-14 | vybrid: backport from meta-fsl-arm master-next | Max Krummenacher | |
remove when moving to dora branch | |||
2013-10-14 | cortex-a5.inc: backport from openembedded-core dora branch | Max Krummenacher | |
revert when moving to dora | |||
2013-10-10 | colibri-vf50: add the machine, kernel and u-boot | Max Krummenacher | |
- also add the relevant configuration files | |||
2012-10-18 | removed *~ backup files from git repo | Max Krummenacher | |
2012-07-21 | removed unneeded apmd from machine features | Max Krummenacher | |
2012-06-03 | Initial commit | Max Krummenacher | |
