OE-Core now requires it for recipes provided by the
openembedded-core layer.
| ERROR: connman-1.41-r0 do_patch: QA Issue: Missing Upstream-Status in patch
Disable BackgroundScan in main.conf.
Related-to: ELB-4148
Signed-off-by: Ming Liu <ming.liu@toradex.com>
(cherry picked from commit 097df183d8e70cfcf4267425c195a6dcfcdbc9ed)
- Drop 0001-connman.service.in-don-t-start-if-nfs-boot.patch, since
commit "ef0d26e6: rootnfs: Working rootnfs using connman", connman
can handle nfs rootfs on NICs.
- Change "+=" to "_append", this could avoid some cases "+=" being
overridden by overrides variables.
(cherry picked from commit fd7a7b83175368f809b237979e3f20304a5571de)
NTP client should not update time and timezone by default unless
otherwise stated in the settings.
Related-to: ELB-2753
Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
(cherry picked from commit 16961c4f190d23d640286b5df73107cbdf27b727)
Version update in oe-core requires patch rebase.
The connman sources provide main.conf with all settings set to default.
Patch that file rather than providing the file in full from a maybe
outdated connman version.
Connman gained support for USB gadget. The typical usecase is to use
USB gadget for tethering. In this use case the module would be the
device sharing the connection to the USB host connected to the module.
However, our typical use case in mind for RNDIS is a simple ethernet
connection between a development host and the module, hence no need
for tethering/routing. This however is not easily doable with connman,
since connman tries to have one connection online only. When enabling
USB gadget as a normal ethernet device, this typically leads to classic
ethernet not being configured since the USB RNDIS connection is already
up and running.
By blacklisting USB gadget, connman won't touch the device and we can
use other means of bringing up the network interface.
