Put the changes we want to make to the default into scripts in /etc/profile.d
and keep the openembedded-core provided /etc/profile.
This keeps the maintained version of /etc/profile rather than having
to manually merge in fixes from the openembedded layer.
We rely on the init system to remount the root file system read-only,
which makes the mount flags for the rootfs in fstab relevant. Since
we run on flash drives minimize write cycles by disabling atime by
by default.
By default systemd utilities use escape sequences to produce colored
output. But systemd also uses less as a pager. The less command
provided in the Toradex demo images is provided by BusyBox, which
does not support color escape sequences. Disable colored output
altogether. This makes output of journalctl much more readable.
Commit 619d15b9a2c53eb8496c807f0f229f5cb192e9d7 in openembedded-core
moves the inputrc file from the base-files to the readline recipe.
Follow that move with our *.bbappend.
This fixes <HOME>, <END> not working as expected on a serial console.
oe-core included resize in their profile too.
Synchronize with the OE solution which already does the redirect.
avoid clash with systemd provided resolv.conf
Collected errors:
* check_data_file_clashes: Package systemd wants to install file ../resolv.conf
But that file is already provided by package base-files
