path: root/recipes-core/systemd/systemd
2017-01-10systemd/rndis.network: don't emit server addressesMax Krummenacher
Don't emit DNS/NTP/Router/Timezone servers addresses to the RNDIS client. We expect RNDIS to be used as a service/debug interface to connect to a module. For this we do not want to reconfigure the connecting device with the modules setup. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2015-08-07Revert "systemd: restore userspace firmware loading support"Max Krummenacher
This reverts commit bd2d32bf3a8460c87849e75ad01e11450d8cda10. Remove the backport, is part of fido.
2015-05-18systemd: restore userspace firmware loading supportJonathan Liu
This changes the minimum required Linux version from 3.7 back to 3.0. [YOCTO #7409] Signed-off-by: Jonathan Liu <net147@gmail.com> Signed-off-by: Richard Purdie <richard.purdie@linuxfoundation.org> backported from openembedded-core, commit 31163abc7bedd477c1aad10e6d1f47dbee194513
2015-05-18Revert "systemd: fix DHCP on link state change"Max Krummenacher
This reverts commit 3cf2edb10f5e8ac60db7ca2e71d1e754a177d08c. Conflicts: recipes-core/systemd/systemd_%.bbappend
2015-05-12systemd: add networkd for RNDIS configurationStefan Agner
Since Connman is better suited for more advanced Wireless solutions, we keep Connman for the main network configuration manager. However, for the simple RNDIS debug/test configuration, Connman is not well suited since Connman tries to maintain one connection only at any given time. This change enables networkd and adds a simple standard configuration for USB/RNDIS network devices.
2015-05-12systemd: fix DHCP on link state changeStefan Agner
When the link goes down, the DHCP service has been disabled, while there is no corresponding functionality which enables the service when the link goes up again. This fix is taken from systemd 217.
2015-03-05journald: remove journald.conf patchMax Krummenacher
meta-angstrom now overrides the effect of the patch and provides the journald.conffile in full. To override a setting either create the file with your settings in meta-toradex/recipes-core/systemd/systemd/journald.conf or edit meta-angstrom/recipes-core/systemd/systemd/journald.conf.
2014-04-01journald patch: update to systemd 206Max Krummenacher
2013-09-22systemd: follow update of recipe with bbappendMax Krummenacher
2013-06-26systemd: fix patch path so the default -p 1 appliesMax Krummenacher
2013-06-07systemd-journald: limit journal sizeMax Krummenacher
