2014-12-18 | systemd-machine-id-commit: add standalone recipe | Max Krummenacher | |
2014-10-30 | timestamp-service: remove in favor of meta-angstrom patch | Max Krummenacher | |
2014-08-04 | timestamp-service: change to new timestamp format | Max Krummenacher | |
Patch pending in meta-angstrom | |||
2014-08-04 | util-linux: fstrim: remove now integrated backport | Max Krummenacher | |
2014-08-04 | bbappends: remove the deprecated PRINC variable | Max Krummenacher | |
2014-08-04 | Use generic bbappend files | Max Krummenacher | |
This uses the % wildcard for recipe matching. remove the deprecated PRINC variable while at it. | |||
2014-04-01 | util-linux bbappend: update to match bb version | Max Krummenacher | |
2014-04-01 | journald patch: update to systemd 206 | Max Krummenacher | |
2014-04-01 | systemd bbappend: update to match bb version | Max Krummenacher | |
2014-04-01 | dropbear connman bbappend: update to match bb version | Max Krummenacher | |
2014-02-04 | util-linux: add fstrim | Max Krummenacher | |
Add the fstrim utility to Colibri T30 image. The utility allows to send trim commands to the underlaying flash translation layer, which allows too free not used flash sectors and those improve wear- leveling | |||
2013-09-22 | dropbear: fix moved path to sftp server | Max Krummenacher | |
2013-09-22 | systemd: systemd bbappend update to version 199 | Max Krummenacher | |
2013-09-22 | systemd: follow update of recipe with bbappend | Max Krummenacher | |
2013-06-26 | systemd: fix patch path so the default -p 1 applies | Max Krummenacher | |
2013-06-07 | systemd-journald: limit journal size | Max Krummenacher | |
2012-12-07 | dropbear: disable reverse DNS lookups | Max Krummenacher | |
2012-08-24 | ${BPN} errors to psplash-angstrom instead of psplash, fetch fails. | Max Krummenacher | |
