2015-02-12 | mmc-utils: add recipe for chromiumos version thereof | Marcel Ziswiler | |
Add a recipe for the Chromium OS version of the mmc-utils able to handle Extended CSD revision 1.7 of the latest MMC 5.0 specification. Some of the more interesting information thereof is the life time estimation and pre EOL information as follows: root@apalis-t30:~# mmc extcsd read /dev/mmcblk0 | \ grep -A 3 'Device life time estimation type A' Device life time estimation type A [DEVICE_LIFE_TIME_EST_TYP_A: 0x01] i.e. 0% - 10% device life time used Pre EOL information [PRE_EOL_INFO: 0x01] i.e. Normal | |||
2014-08-04 | bbappends: remove the deprecated PRINC variable | Max Krummenacher | |
2014-04-01 | systemd-compat-units: ensure that postinst is run | Max Krummenacher | |
The combination of changes lead to the postinst scripts not beeing run at all. | |||
2013-09-22 | python-numpy: bbappend deleted, now fixed in openembedded layer | Max Krummenacher | |
2013-02-06 | python-numpy: backport fix of changed python-native path | Max Krummenacher | |
2012-06-12 | - mklibs is no longer downloadable in the 0.1.33 version, upgrade to next ↵ | Max Krummenacher | |
version |
