path: root/recipes-gnome/gdk-pixbuf
2016-09-28gdk-pixbuf_%.bbappend: delete, moved to meta-lxdeMax Krummenacher
This bbappend is required by packages built with meta-lxde. Thus move it were it belongs. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2016-03-14gdk-pixbuf_%.bbappend: build for x11 dependend on DISTROFEATURESMax Krummenacher
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2014-08-04Use generic bbappend filesMax Krummenacher
This uses the % wildcard for recipe matching. remove the deprecated PRINC variable while at it.
2014-04-01gdk-pixbuf bbappend: update to match bb versionMax Krummenacher
2013-09-22gdk-pixbuf: change to the new X11DEPENDS for overrideMax Krummenacher
2013-09-22gdk-pixbuf: bbappend updated to 2.26.5Max Krummenacher
2013-06-26gdk-pixbuf: update icon cache on rootfs build timeMax Krummenacher
2012-06-03Initial commitMax Krummenacher
