path: root/recipes-gnome/gvfs
2019-03-06gvfs: add libusb to dependsMax Krummenacher
Without gphoto libusb is otherwise not available and configure fails. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-03-06gvfs: sync with upstreamMax Krummenacher
meta-openembedded no longer builds with samba in PACKAGE_CONFIG. Thus drop removing it here. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-01-10gvfs bbappend: use version wildcardMax Krummenacher
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2016-03-14gvfs_1.10.1.bbappend: don't build with gphotoMax Krummenacher
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-03-14gvfs: use _remove to not build with sambaMax Krummenacher
2015-05-18gvfs: add missing dependency on libgudevMax Krummenacher
2015-03-31gvfs: remove samba from PACKAGECONFIGMax Krummenacher
compiling gvfs with samba support in dizzy does not only pull in smbclient but the full samba package, i.e. 50MB+.
2014-08-04gvfs: don't use samba-client on vybridMax Krummenacher
save space by not requiring smbclient.
