2014-10-30 | xinput-calibrator: remove systemd service | Stefan Agner | |
Remove xinput-calibrator systemd service since autostart is done using /etc/xdg/autostart/xinput_calibrator.desktop. | |||
2014-08-04 | bbappends: remove the deprecated PRINC variable | Max Krummenacher | |
2013-09-22 | systemd: adapt to new systemd handling | Max Krummenacher | |
with the move from meta-openembedded to oe-core some things have changed, e.g. the config files have to explicitly installed | |||
2013-09-22 | xinput-calibrator: menuentry behaves as the first boot calibration | Max Krummenacher | |
- make the menuentry behave as the one time calibration on first boot | |||
2013-09-22 | xinput-calibrator: bbappend updated to use git instead of versioned tarball | Max Krummenacher | |
