As e.g. our Tegra modules are multihead capable and if HDMI is plugged
in while the xinput calibrator was run this led to the following error
message:
root@apalis-t30:~# xinput_calibrator_once.sh
Unknown option: 640x480
Fix this by just using the first detected heads geometry definition.
${PN} might be extended with some magic prefix, so don't use it in SRC_URI
assignments et. al.
Remove xinput-calibrator systemd service since autostart is done
using /etc/xdg/autostart/xinput_calibrator.desktop.
If the xinput-calibrator.service is enabled but lxdm.service is disabled lxdm
was started anyway because of the requires dependency.
Replase Requires with Requisite to have xinput-calibrator.service fail instead.
(cherry picked from commit e34e6361ecaaa8b148d438d517761bdd084d1a32)
with the move from meta-openembedded to oe-core some things have
changed, e.g. the config files have to explicitly installed
- make the menuentry behave as the one time calibration on first boot
on first boot
