For low-end modules without GPU only show the QT analogclock. For TK1
also choose a different QT-demo.
Related-to: ELB-3153
(cherry picked from commit c79cc904871adae96d1c0d0743c5a2605cb25e20)
0.5 seconds is not enough in some cases. Wait a little bit longer
to avoid having the app restarted multiple times.
Related-to: ELB-2838
And limit the restart to once per second.
The desktop file has key 'MimeType' which mandates 'inhert mime-xdg'.
Related-to: ELB-1284
Add the missing RDEPENDS.
We want to choose different display managers for different image
recipes. Thus do not inject one through this packagegroup.
The service expects the script to return (Type=forking). Change the script
so that the wayland app is started in the background.
While at it configure the service to restart the application.
This tries to start a wayland application after weston got started.
Create a copy of wayland-terminal-launch_1.0.bb with the variables
changed according to your needs.
RDEPENDS is set by bitbake to an empty string, so using ?= is pointless.
This recipe starts xterm as the first X11 application.
Pull out common code so that the bb file only contains information about
the application which is to be started.
Rename the recipe so that one knows what is going to be started.
The changes have been added upstream.
This reverts commit d568bc40cabdb27fb1948206b8d2f3f911f6e252.
Revert once 8382cdc0888ca645a44aacaac1155afb8dcde979 and
77c353cc9bdfbf1b6453b2579b72726db05eb69c are backported to rocko.
cogl-1.0 is empty, so remove the RDEPEND on it from the -dev package.
| * Problem 1/1:
| * - package cogl-1.0-dev-1.22.2-r0.armv7at2hf-neon-mx6qdl requires
cogl-1.0 = 1.22.2-r0, but none of the providers can be installed
The original website linuxbrit.co.uk has definitly vanished, so
use Fedora mirrors by default. It appears that the mirror prepend
solution messed with the Toradex mirrors.
After the xserver-nodm-init started the Xserver this provides a script to
start exactly one X application.
Change the variables INITIAL_PATH and X_APPLICATION to the specify the
current working directory when starting the application and the path to
The terminal output is not seen.
Move needed stuff from efl.bbclass inside the recipe.
Resurrect from meta-openembedded/meta-efl.
Empty RDEPENDS are not needed, the others are automatically added
by the buildsystem.
As e.g. our Tegra modules are multihead capable and if HDMI is plugged
in while the xinput calibrator was run this led to the following error
message:
root@apalis-t30:~# xinput_calibrator_once.sh
Unknown option: 640x480
Fix this by just using the first detected heads geometry definition.
silence warning for hash-style not gnu
WARNING: unclutter-1.09-r0 ... No GNU_HASH in the elf binary: '...unclutter' [ldflags]
Fixes:
| ERROR: giblib-1.2.4-r0 do_populate_sysroot: QA Issue: giblib.pc failed sanity test (tmpdir) in path .../work/armv7at2hf-neon-angstrom-linux-gnueabi/giblib/1.2.4-r0/sysroot-destdir/usr/lib/pkgconfig [pkgconfig]
This bbappend is required by packages built with meta-lxde.
Thus move it were it belongs.
The evdev version provided by oe-core is in the meantime newer than
this backport, hence we can safely remove it.
The upstream server currently gives error 403.
$ wget http://linuxbrit.co.uk/downloads/scrot-0.8.tar.gz
--2015-09-17 10:50:25-- http://linuxbrit.co.uk/downloads/scrot-0.8.tar.gz
Resolving linuxbrit.co.uk (linuxbrit.co.uk)... 65.110.41.18
Connecting to linuxbrit.co.uk (linuxbrit.co.uk)|65.110.41.18|:80... connected.
HTTP request sent, awaiting response... 403 Forbidden
2015-09-17 10:50:25 ERROR 403: Forbidden.
(cherry picked from commit 77e6a09a5afeab9f0d550b3319e134ec991f50cf)
gpu-viv-bin-mx6q -> imx-gpu-viv
with a bunch of subpackages.
PublicDomain is not known to OE
Neiter graphviz_2.32.0.bb graphviz_2.38.0.bb work with dizzy.
Uses python directory from build host.
The SUMMARY variable gives a short description of the package (<72 chars).
A missing DESCRIPTION is automatically set to the content of SUMMARY.
${PN} might be extended with some magic prefix, so don't use it in SRC_URI
assignments et. al.
This is also done by the session manager effectively starting the
autostart items twice.
Remove xinput-calibrator systemd service since autostart is done
using /etc/xdg/autostart/xinput_calibrator.desktop.
This uses the % wildcard for recipe matching.
remove the deprecated PRINC variable while at it.
Two popular VNC clients:
- DirectVNC based on DirectFB (e.g. without X11)
- TightVNC based on X11
(cherry picked from commit ef4113208de357a5b8accd7610f8bf3230125a59)
