path: root/recipes-images/images/angstrom-lxqt-image.bb
2018-12-18recipes-images: images: update image descriptionGerard Salvatella
Tezi now shows the image description more prominently. Update the standard image descriptions using DESCRIPTION. Signed-off-by: Gerard Salvatella <gerard.salvatella@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2018-06-18images: remove uclibc overrideMax Krummenacher
uClibc has been removed in morty. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-03-22apalis-tk1-mainline: append summary indicating mainlineMarcel Ziswiler
Images for tk1 and tk1-mainline are currently indistinguishable especially when path to the image is long. For now simply append the description with " (Mainline)" should work. Let’s integrate this into our builds. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-03-22recipes: use oe.utils.conditional instead of deprecated base_conditionalMax Krummenacher
2018-03-22angstrom-lxqt-image: remove snapdMax Krummenacher
From feedback it looks like it is not widely used but it adds a lot to the final image as well as to build time as it relies on go and go-native. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-03-22images: add gstreamer1.0-plugins-good-multifileMarcel Ziswiler
Trying to store PNG files off our CSI Camera Module 5MP OV5640 on Apalis TK1 revealed the first few frames to be black resp. greenish. One way to overcome this is to save several images and just throw the first few away. In order to do so the multifilesink plug-in would be needed: gst-launch-1.0 v4l2src device=/dev/video0 ! 'video/x-raw,format={UYVY},width=640,height=480' ! videorate max-rate=10 ! videoconvert ! avenc_png ! multifilesink location=test%d.png Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2018-03-22images: remove adwaita-icon-theme from bad_recommendsMax Krummenacher
gpicview has an RDEPENDS on adwaita-icon-theme. Having adwaita-icon-theme in BAD_RECOMMENDS prevents gpicview from being installed. (Because gpicview itself is pulled in through a RRECOMMENDS) Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-03-22angstrom-lxqt-image: point out qt licencesMax Krummenacher
Provide a link to the Qt website with licensing information. Split out GPL-3.0 modules into their own variable to ease removal of these module. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-03-22angstrom-lxqt-image: add a connman pluginMax Krummenacher
2018-03-22angstrom-lxqt-image: add a new image recipeMax Krummenacher
An image with an LXQt desktop. This requires the meta-qt5-extra layer. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
