packagegroup-base-extended is installed by inheriting core-image.
packagegroup-basic installs dropbear, openssh-sftp, openssh-sftp-server
dropbear can act as an scp client, drop openssh-scp
Define the string used for each machine in the machine configuration
rather than doing this in each image recipe.
Fallback to machine configuration name if not defined.
populate_sdk_qt5"
This reverts commit 0af5df0bd71d1714c1b2623fd9f6d57619926278.
meta_qt5 got fixed so that it is no longer needed to force an inherit order.
This prevents that with every build of the image the sdk is also built.
Also apply the same to lxqt-image.
This is a follow-up to:
e1026cf43 images: do not explicitely install ${XSERVER}
This among others installs modeprint, modetest.
We decided we won't do a BSP 3.0 for Vybrid.
For new designs we recommend ULL now.
Use the Toradex Easy Installer instead.
If you included tdx-image-fstype.inc in your image recipes you will have
to remove that include.
This is added through distro features settings.
gstreamer1.0-libav needs commercial licenses to be whitelisted,
thus only install it when this is allowed through configuration.
E.g. add
LICENSE_FLAGS_WHITELIST = "commercial_gstreamer1.0-libav" to local.conf
to allow installing libav.
