The machine.conf sets the needed u-boot-fw-utils flavour with PREFERRED_PROVIDER.
Thus us the generic u-boot-fw-utils in IMAGE_INSTALL.
This installs the full featured util-linux applications and preferes them
over the busybox variants at the price of a bigger rootfs.
Related to: #49287
The Wi-Fi drivers from kernel 4.14 provide all needed features. So don't
bother with backports.
While at it move all Wi-Fi related packages into the Wi-Fi variables.
packagegroup-base-extended is installed by inheriting core-image.
packagegroup-basic installs dropbear, openssh-sftp, openssh-sftp-server
dropbear can act as an scp client, drop openssh-scp
We used to do this in the dropped tdx-image-fstype.inc.
We decided we won't do a BSP 3.0 for Vybrid.
For new designs we recommend ULL now.
No change in what gets installed intendend.
This among others provides taskset.
can-utils support CAN-FD which canutils does not.
The backports recipe does not yet work with the kernel used for
apalis-imx8 and colibri-imx8qxp.
The backports configuration does not match the kernel used.
These machines use an old Nvidia provided downstream kernel 3.1.10.
They are no longer compatible with more recent sysroot components,
e.g. libc, xserver et. al.
The maintenance burden to keep the userspace components in their old version
becomes simply to high. Keep using the rocko based 2.8 BSP for these machines.
The U-Boot fw-utils recipe was moved to meta-freescale. While moving
the recipe name was renamed, follow that.
How can one even live without util-linux-lsblk? Let's add it.
In order to reboot from Linux with a pulse on RESET_OUT# we now get a
cold boot with which the used mechanism for bmode is no longer usable.
To free-up some space, since the legacy update system is limited
in size for flashing.
Signed-off-by: Gerard Salvatella <gerard.salvatella@toradex.com>
Perf is included in oe-core. The default configuration has been assumed
to suffice.
Quickly tested on Colibri imx6 with 4.9 Kernel.
Add bluez-alsa to allow playing audio over the Colibri iMX6ULL's
on-board Bluetooth chip.
Build hostapd for all platforms.
Add U-Boot fw-utils (fw_set/printenv) to the Colibri iMX6ULL
image.
The correct recipe for package gdbserver is now found without an
explicit DEPENDS. DEPEND on gdb-cross-arm actually no longer builds
gdbserver.
The package has been split into a pure library package (libusbgx)
and a package with programs and example configuration (libusbgx-
examples). The latter brings gadget-export/import, and the sample
configurations Toradex images typically load on startup.
Backports for mainline currently fails building but also kind of does
not make much sense. However some customers might need the firmware.
Firmware for the Wi-Fi module on the Colibri iMX6ULL.
This adds the backports usable for all modules unconditionally
and the ones usefull for Apalis (PCIe) specifically to all
Apalis machines.
With the move to backports we added firmware packages in the
backports section and kept in the unconditional part.
Remove one of them.
LM816 wifi dongle uses this fw.
This is for some time done in oe-core without any intervention:
meta/classes/rootfs-postcommands.bbclass
Add this in IMAGE_PREPROCESS so that all image types get this
change.
The only machine which did not install canutils is colibri-t30.
Install it in all images. iproute2 is pulled in from canutils so
remove its explicit installation.
While at it cleanup curl which is included unconditianallly and in
the machine specfic parts.
Introduce packagegroup which contains the dependencies required to
use the .NET Core runtime.
Add a trailing ';' to separate from commands appended later.
The library libunwind is a dependency for the .NET Core 2.0
runtime. Preinstall it in our standard images.
This adds the bmode_usb binary to the i.MX6 rootfs which allows to
set some i.MX6 registers so, that on the next reboot (not powercycle)
the i.MX6 starts in serial download mode (aka. recovery mode).
