Provide a higher ranking video sink plugin than the not working
imxeglvivsink and thus fixes automatic (playbin) pipeline construction
and audio mpeg codec warning (AAC codec).
Additionaly include a NXP userspace cli tool to play or record with
gstreamer.
Related-to: ELB-3013
Related-to: ELB-3010
Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
Without qtwayland deployed QT is not working on wayland.
Related-to: ELB-3153
For low-end modules without GPU only show the QT analogclock. For TK1
also choose a different QT-demo.
libdrm-tests contains the useful binary modetest to check the different
kernel mode setting parameters. This doesn't make sense to deploy for
downstream images so only deploy this to mx8 and upstream images.
Related-to: ELB-3048
We dropped our own package split rtl8188eu in favour of the
openembedded-core provided rtl8188 which contains the firmware for
both rtl8188 and rtl8188eu.
(cherry picked from commit 186472283cb83de812e8d8c0f7682bd4048edc9a)
After moving the images to the kernel toradex_5.4-2.1.x-imx,
backport-5.4 got obsolete. Exclude backports from images.
Related-to: ELB-2891
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
Two more tools we use in testing of module features.
Related-to: ELB-2874
Related-to: ELB-2838
console-tdx-image.bb -> tdx-reference-minimal-image.bb
verification-tdx-image.bb -> tdx-reference-multimedia-image.bb
This plugins are no longer available and they are also not needed for the
Apalis TK1 with mainline kernel.
(cherry picked from commit 3ea7634828544a2699cc364dac68081ddd35520b)
With use-mainline-bsp the SoC overrides mx6/mx6q/mx6ull... are filtered out of
the overrides. Replace them with the specific machine name if the override
should also be active in the use-mainline-bsp case for that machine.
Related-to: ELB-2805
(cherry picked from commit 31a39f3502bb0b7c3012a2adc61442d3d2547557)
The recipe assosiates mimetypes with multimedia applications which do
no longer exist.
It targets also desktop like images and are not that useful in embedded.
Rather than rework it, drop it.
(cherry picked from commit 74bce843e8768e86494da19814bf52a4844b5db7)
Completes commit 8974d4bb8841 ("apalis-tk1-mainline: drop override use").
The downstream kernel gets to old to be used with the new zeus
userspace components. Reuse the apalis-tk1 machine name to build
a mainline kernel and drop the apalis-tk1-mainline machine.
Related-to: ELB-2733
(cherry picked from commit 3a3f62d5002582ca064e8019f517fc538b763ef3)
- Drop LICENSE from graphical-tdx-image and verification-tdx-image,
it's already defined in console-tdx-image recipe.
- Drop deprecated variables ROOTFS_PKGMANAGE_PKGS, IMAGE_DEV_MANAGER,
IMAGE_INIT_MANAGER, IMAGE_INITSCRIPTS, IMAGE_LOGIN_MANAGER.
- timestamp-service is a systemd specific package, install it only for
systemd distro.
- Change udev-extra-rules to udev-extraconf, udev-extraconf is the new
name after merging udev-extraconf and udev-extra-rules in OE:
[ 0ca3a7823: udev-extraconf: Merge with udev-extra-rules from meta-oe ]
Signed-off-by: Ming Liu <ming.liu@toradex.com>
(cherry picked from commit 02531024c1bdcb64174ca75bfc674f3864361fd5)
Install the wifi firmware group to the image.
Firmware files required by several wifi devices including
mrvl8688/rtl8188 that provide by Toradex as on-module and standalone
USB solutions.
Related-to: ELB-2789
(cherry picked from commit 1b11f919335186220c3be77e6d73f4ed5a2fda0d)
This will add an example hostapd package that will contain all necessary
files to just "enable" an acces-point on a demo image.
Relates-to: ELB-1303
(cherry picked from commit 7873d287300c204c594bc46429bca066cbd68bea)
The tegra124 machines use a recent mainline kernel, so the backports package
which provides drivers of a recent mainline kernel to older kernels is not
needed.
(cherry picked from commit 93533eade29f2379519548361d6f051f0712909d)
(cherry picked from commit 8974d4bb8841dfb3372a34bf645a11f2f4f957d4)
(cherry picked from commit 24a363e552c2e2d0cffa6f0eb4db3b0a6a992a33)
Related-to: ELB-1429
(cherry picked from commit 26ca76420fcd10853a14b5ca5b93f55549e647d6)
(cherry picked from commit a7fe3b21d6402bdf4b4cc9981158fbf7646a37b1)
Since the images inherit console-tdx-image.bb (mainline) is appended
multiple times to the image.json name property.
gpsd is used with the GPS receiver in our test setup.
(cherry picked from commit a2d99bf7b054aa3c696b8c95d9b6be2bf49727c8)
phytool allows to read and write Ethernet PHY registers from userspace.
(cherry picked from commit 0abfeb0fef33da16150aa8bd78672292e368b185)
smem is a python script which present memory usage info gathered
from the proc filesystem.
(cherry picked from commit 4a9cb68f966cc0b6f7cff66f1b9cf549f540915d)
Add the missing depends, so that the common gstreamer packages get installed.
(cherry picked from commit f06aa0d1c688ea8c7212bb20f03aac95d93d8904)
(cherry picked from commit bac782c8c3d1b74cf97298a4d074f873558eadc4)
As no image uses firefox, stop touching the recipe.
Thus this layer no longer depends on meta-browser.
As no image uses lxde, stop touching the recipes.
Thus this layer no longer depends on meta-lxde.
Related-to: ELB-1284
gstreamer 0.10 support is dropped in oe-core. Thus only install gstreamer 1.0
based components. Note that the TK1 support for gstreamer 1.0 is less
complete.
This is meant to replace the current demo images.
The console and graphical image can be used as a base to create tailored
images to the requirment of a specific use case.
The verification image is meant to test the BSP. It provides the tools
to exercise the CPU / GPU / VPU and the various SOC peripherals.
Drop PV to denote the image version. Using timestamps in PV causes
various issues. The image PV has not much meaning other than it has
been used by the Tezi image class. Sidestep by using DISTRO_VERSION
directly in the Tezi image class. See also:
http://lists.openembedded.org/pipermail/openembedded-core/2019-November/289765.html
Also only write /etc/issue in the do_rootfs task instead of writing
it in base-files first and then change it in do_rootfs. We sligtly
alter the login banner:
Before:
TDX X11 2.6-snapshot colibri-imx7-emmc ttymxc0
Colibri-iMX7-eMMC_Console-Image 3.0b2.65 20190830
With this change:
TDX X11 0.0.0-dev-20191103+build.12 (zeus) colibri-imx7-emmc ttymxc0
OE dropped the obsolete gstreamer version 0.10.
OE-core dropped eglinfo, thus remove it from our image recipes.
aa36510ebe eglinfo: remove the recipe
This package was dropped with the move to Qt 5.13.
https://bugreports.qt.io/browse/QTBUG-70510
meta-qt5 dropped the recipe.
See https://github.com/meta-qt5/meta-qt5/commit/7cc177d116ad98d0c922f98aa7f02c2cc655c0ec
This allows on newer (>=4.8) kernels to access the new gpio interface
through /dev/gpiochipX character devices.
https://git.kernel.org/pub/scm/libs/libgpiod/libgpiod.git/tree/README
Linux kernels >= 4.8 lack of strong entropy after boot.
This leads to long delay in starting wide class of applications
like ssh, qterminal etc.
Adding entropy helper service fixes this issue.
- add haveged daemon for tegra soc series
- add rng-tools for all other soc series.
With the move away from angstrom we lost some networking and debugging
tools which angstrom did install by default. Add them again here.
avahi-autoipd ppp procps strace
The machine.conf sets the needed u-boot-fw-utils flavour with PREFERRED_PROVIDER.
Thus us the generic u-boot-fw-utils in IMAGE_INSTALL.
This installs the full featured util-linux applications and preferes them
over the busybox variants at the price of a bigger rootfs.
Related to: #49287
The Wi-Fi drivers from kernel 4.14 provide all needed features. So don't
bother with backports.
While at it move all Wi-Fi related packages into the Wi-Fi variables.
