path: root/recipes-kernel/linux/linux-toradex-fsl_git.bb
2016-03-14Apalis/Colibri iMX6: drop in favour of meta-fsl-arm-extraMax Krummenacher
machine/u-boot/kernel files have been added to meta-fsl-arm-extra. Use them from there now. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2015-12-15linux-toradex-fsl: update to latest revisionMax Krummenacher
Update to latest revision which fixes Colibri iMX6D not powerering off but creating a stacktrace. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2015-11-04Apalis/Colibri iMX6: Update Linux kernel to latestMax Krummenacher
2015-11-04linux: fix B != SMarcel Ziswiler
2015-11-04apalis/colibri_imx6/t20/t30: add version/git hash to KernelStefan Agner
Add LOCALVERSION and generate a scmversion file to annotate the Kernel with the Toradex release and a git hash.
2015-11-04apalis/colibri_imx6: update/load USB Gadget ConfigFS automaticallyStefan Agner
Since we use USB Gadget ConfigFS now use libusbg to load the USB Gadget configuration automatically.
2015-11-03Update Linux kernel and U-Boot to latest.Marcel Ziswiler
2015-10-12Apalis iMX6: cleanup filename for V1.0 HWMax Krummenacher
Follow the rename imx6q-apalis-eval_v1_0.dtb to imx6q-apalis_v1_0-eval.dtb in the kernel. The v1_0 denotes the Apalis module version, not the evaluation board version.
2015-10-12apalis-imx6: update kernel to toradex_imx_3.14.28_1.0.0_ga-nextMax Krummenacher
2015-08-07kernel: adapt to oe's new shared work dirMax Krummenacher
2015-05-18Apalis/Colibri iMX6: use toradex_imx_3.10.17_1.0.0_ga branchMax Krummenacher
2015-05-18Apalis/Colibri iMX6: update kernel to latest in -nextMax Krummenacher
2015-05-12Apalis/Colibri iMX6: kernel/U-Boot update to latest in -nextMax Krummenacher
Also deploy an additional device tree supporting a Colibri iMX6 with Analog Camera Module.
2015-05-12linux-toradex-fsl_git.bb: remove 3.0.15 Vybrid KernelMax Krummenacher
This removes the 3.0.15 based Kernel for Colibri VFxx. Since some time now we use a more recent Kernel provided from the linux-toradex-vf_3.18.bb recipe.
2015-05-12recipes: replace short DESCRIPTION with SUMMARYMax Krummenacher
The SUMMARY variable gives a short description of the package (<72 chars). A missing DESCRIPTION is automatically set to the content of SUMMARY.
2014-12-18Update all to latest and greatest U-Boot and Linux kernel.Marcel Ziswiler
2014-12-11colibri-vf: update KernelMax Krummenacher
2014-12-11apalis/colibri-imx6: U-Boot and Kernel for V1.0/V1.1Max Krummenacher
Update to a U-Boot and Kernel which can be used for Apalis iMX6 HW version V1.0 and V1.1. Also deploy additional device tree for Apalis iMX6 V1.0 modules
2014-11-13Apalis/Colibri iMX6/T20/T30/VF50/VF61: rev kernel version to V2.3b4Marcel Ziswiler
2014-10-30linux: iMX6/VF update to latest from gitMax Krummenacher
2014-10-06colibri-imx6: refactor recipes for new moduleMax Krummenacher
2014-08-04apalis-imx: update kernel to 3.10.17Max Krummenacher
Base kernel on Freescales 3.10.17_1.0.0_ga and provide a device tree plus code changes for Apalis iMX6.
2014-08-04colibri-vf: update kernel to latest, port recipe for use with daisyMax Krummenacher
2014-08-04linux-toradex-fsl: remove linux-toradex-fsl.inc usageMax Krummenacher
2014-05-20colibri-vf: switch back to latest git on colibri_vf branchMarcel Ziswiler
This commit switches Colibri VF machine back to use the colibri_vf branch and use the latest Linux kernel.
2014-04-30colibri-vf: switch to U-Boot 2014.04 and latest gitStefan Agner
This commit switches Colibri VF machine to use the 2014.04 git branch. The change to latest U-Boot brings proper NAND hardware ECC support, which is also enabled in latest Linux kernel. Beside that, burnflash is updated to correctly work with the new U-Boot version and the altered Config Block location.
2014-04-05linux-toradex-fsl_git: fix parsingMax Krummenacher
Make the bitbake parser not fail when this recipe is parsed for a machine for which this recipe is not a COMPATIBLE_MACHINE.
2014-04-03kernel: apalis-imx6 update to latest git versionMax Krummenacher
2014-04-02kernel: apalis-imx6 update to latest git versionMax Krummenacher
2014-04-01kernel: add Apalis iMX6 and Colibri VF recipeMax Krummenacher
