index
meta-toradex-demos.git
dunfell-5.x.y
jethro
jethro-next
kirkstone-6.x.y
master
morty
morty-next
rocko
rocko-next
scarthgap-7.x.y
thud
thud-next
zeus
Toradex BSP layer, recipes for the demo images
Toradex
summary
refs
log
tree
commit
diff
log msg
author
committer
range
path:
root
recipes-kernel
Age
Commit message (
Collapse
Author
2013-10-10
colibri-vf50: add the machine, kernel and u-boot
Max Krummenacher
- also add the relevant configuration files
2013-09-22
linux-firmware_git: remove bbappend, recipe now more granular
Max Krummenacher
2013-01-29
kernel: unified the recipes for all toradex kernels
Max Krummenacher
2013-01-22
kernel: update to latest on git.toradex.com
Max Krummenacher
2012-12-31
update u-boot and kernel git versions
Max Krummenacher
remove testfile
2012-12-18
Max Krummenacher
2012-12-07
kernel: remove all fiddeling with the defconfig, compile the kernel as it is ↵
Max Krummenacher
in git
2012-11-19
linux-firmware: split the Ralink firmware into its own package
Max Krummenacher
2012-10-18
kernel: use latest from git
Max Krummenacher
2012-10-18
update to latest colibri kernel
Max Krummenacher
2012-10-18
kernel tools breaks the build
Max Krummenacher
2012-10-18
merge with L4T R16 kernel
Max Krummenacher
2012-08-23
Use kernel and u-boot from git.toradex.com
Max Krummenacher
Move changes done to other repos into .bbappends in meta-toradex
2012-08-15
L4T R15, oe-core Image V2.0Beta1
Max Krummenacher
2012-07-21
pull u-boot unified for vibrante and l4t and the corresponding l4t kernel
Max Krummenacher
2012-07-19
change to 3.1. L4T kernel, take it from git.toradex.com
Max Krummenacher
2012-06-19
Update to new NV binary packages L4T R15
Max Krummenacher
Removed nvrm_deamon and corresponding init.d script Kernel from git.toradex.int
2012-06-03
Initial commit
Max Krummenacher
