2015-05-12 | update U-Boot and Colibri VFxx Linux to latest git revision | Stefan Agner | |
2015-05-12 | Apalis/Colibri iMX6: kernel/U-Boot update to latest in -next | Max Krummenacher | |
Also deploy an additional device tree supporting a Colibri iMX6 with Analog Camera Module. | |||
2015-05-12 | colibri_vf: update to U-Boot 2015.04/Linux 4.0 | Stefan Agner | |
2015-05-12 | linux-toradex-fsl_git.bb: remove 3.0.15 Vybrid Kernel | Max Krummenacher | |
This removes the 3.0.15 based Kernel for Colibri VFxx. Since some time now we use a more recent Kernel provided from the linux-toradex-vf_3.18.bb recipe. | |||
2015-05-12 | recipes: replace short DESCRIPTION with SUMMARY | Max Krummenacher | |
The SUMMARY variable gives a short description of the package (<72 chars). A missing DESCRIPTION is automatically set to the content of SUMMARY. | |||
2015-03-19 | colibri-vf: update to top of -next branch | Stefan Agner | |
Update to top of -next branch which also includes FEC unbind fixes. | |||
2015-02-03 | colibri-vf: update Linux kernel and U-Boot git hashes | Stefan Agner | |
Also update default defconfig for colibri-vf. | |||
2014-12-19 | colibri_vf: update U-Boot and Linux kernel git hashes | Stefan Agner | |
Two last minute fixes: Default Product/Vendor ID for USB peripheral in U-Boot and fix for the USB peripheral RNDIS freeze. | |||
2014-12-18 | Update all to latest and greatest U-Boot and Linux kernel. | Marcel Ziswiler | |
2014-12-18 | mcc-kmod: use mcc kernel module from toradex git | Stefan Agner | |
In order to make the MCC kernel module working with our newer kernel some changes had been made on the MCC kernel module. The changes are available on the Toradex Github account. Get the MCC kernel module sources from Github. | |||
2014-12-16 | colibri-vf: switch to mainline kernel based on 3.18 | Stefan Agner | |
Switch default kernel recipe to linux-toradex-vf which will build a kernel based on the toradex 3.18-next branch. | |||
2014-12-11 | colibri-vf: update Kernel | Max Krummenacher | |
2014-12-11 | apalis/colibri-imx6: U-Boot and Kernel for V1.0/V1.1 | Max Krummenacher | |
Update to a U-Boot and Kernel which can be used for Apalis iMX6 HW version V1.0 and V1.1. Also deploy additional device tree for Apalis iMX6 V1.0 modules | |||
2014-11-13 | Apalis/Colibri iMX6/T20/T30/VF50/VF61: rev kernel version to V2.3b4 | Marcel Ziswiler | |
2014-11-13 | colibri-vf: add mainline kernel recipe | Stefan Agner | |
Add recipe to build mainline kernel. Currently, the 3.17 next branch will be built. To use this kernel, add this lines to your local.conf PREFERRED_PROVIDER_virtual/kernel ?= "linux-toradex" IMAGE_INSTALL_append = "kernel-devicetree" KERNEL_DEVICETREE += "vf500-colibri-eval-v3.dtb vf610-colibri-eval-v3.dtb" Also, the multi-core communication packages (mqxboot, libmcc, mcc-pingpong and kernel-module-mcc) need to be removed from recipes/images/trdx-extra.inc since the required kernel interfaces are not available on the 3.17 mainline port. | |||
2014-10-30 | linux: iMX6/VF update to latest from git | Max Krummenacher | |
2014-10-06 | colibri-imx6: refactor recipes for new module | Max Krummenacher | |
2014-08-04 | apalis-imx: update kernel to 3.10.17 | Max Krummenacher | |
Base kernel on Freescales 3.10.17_1.0.0_ga and provide a device tree plus code changes for Apalis iMX6. | |||
2014-08-04 | colibri-vf: update kernel to latest, port recipe for use with daisy | Max Krummenacher | |
2014-08-04 | linux-toradex-fsl: remove linux-toradex-fsl.inc usage | Max Krummenacher | |
2014-08-04 | mcc/m4: use recipes from meta-fsl-arm | Max Krummenacher | |
deleted: recipes-bsp/libmcc/libmcc_1.04.bb deleted: recipes-bsp/mqxboot/mqxboot_1.0.bb deleted: recipes-kernel/kernel-module-mcc/kernel-module-mcc_1.04.bb | |||
2014-05-20 | colibri-vf: switch back to latest git on colibri_vf branch | Marcel Ziswiler | |
This commit switches Colibri VF machine back to use the colibri_vf branch and use the latest Linux kernel. | |||
2014-05-07 | linux-toradex: rename linux.inc to avoid layer order dependency | Stefan Agner | |
The include files (such as linux.inc) are not resolved by priority but on layer order instead. This can lead to build errors in case the layers in BBLAYERS are ordered differently. | |||
2014-04-30 | colibri-vf: switch to U-Boot 2014.04 and latest git | Stefan Agner | |
This commit switches Colibri VF machine to use the 2014.04 git branch. The change to latest U-Boot brings proper NAND hardware ECC support, which is also enabled in latest Linux kernel. Beside that, burnflash is updated to correctly work with the new U-Boot version and the altered Config Block location. | |||
2014-04-05 | linux-toradex-fsl_git: fix parsing | Max Krummenacher | |
Make the bitbake parser not fail when this recipe is parsed for a machine for which this recipe is not a COMPATIBLE_MACHINE. | |||
2014-04-03 | kernel: apalis-imx6 update to latest git version | Max Krummenacher | |
2014-04-02 | kernel: apalis-imx6 update to latest git version | Max Krummenacher | |
2014-04-01 | kernel: add Apalis iMX6 and Colibri VF recipe | Max Krummenacher | |
2014-04-01 | colibri-vf: use meta-fsl* layer for BSP files | Max Krummenacher | |
remove the files copied from meta-fsl* for Colibri-VF V2.1 move the colibri-vf u-boot and kernel stuff to meta-fsl-arm-extra | |||
2014-03-18 | kernel vybrid: update to latest | Max Krummenacher | |
2014-03-17 | kernel/u-boot: update to latest git revision | Stefan Agner | |
2014-03-17 | vybrid: backport Cortex-M utilites from meta-fsl | Stefan Agner | |
- Add utility mqxboot to load firmware into IRAM and reset M4 - Add kernel module mcc needed by libmcc - Add multi-core communication library libmcc for message queue based communication with Cortex-M core | |||
2013-12-02 | kernel: update to latest git | Max Krummenacher | |
2013-11-21 | kernel: colibri-vf: use the unified kernel 50/60 | Max Krummenacher | |
2013-11-21 | Machine: use the changed machinename colibri-vf | Max Krummenacher | |
2013-11-05 | Use double-quotes to make script work using dash (debian/ubuntu default) | Stefan Agner | |
2013-10-23 | linux: update to latest git versions | Max Krummenacher | |
2013-10-10 | colibri-vf50: add the machine, kernel and u-boot | Max Krummenacher | |
- also add the relevant configuration files | |||
2013-09-22 | linux-firmware_git: remove bbappend, recipe now more granular | Max Krummenacher | |
2013-01-29 | kernel: unified the recipes for all toradex kernels | Max Krummenacher | |
2013-01-22 | kernel: update to latest on git.toradex.com | Max Krummenacher | |
2012-12-31 | update u-boot and kernel git versions | Max Krummenacher | |
remove testfile | |||
2012-12-18 | kernel: update to latest on git.toradex.com | Max Krummenacher | |
2012-12-07 | kernel: remove all fiddeling with the defconfig, compile the kernel as it is ↵ | Max Krummenacher | |
in git | |||
2012-11-19 | linux-firmware: split the Ralink firmware into its own package | Max Krummenacher | |
2012-10-18 | kernel: use latest from git | Max Krummenacher | |
2012-10-18 | update to latest colibri kernel | Max Krummenacher | |
2012-10-18 | kernel tools breaks the build | Max Krummenacher | |
2012-10-18 | merge with L4T R16 kernel | Max Krummenacher | |
