path: root/recipes-lxde/lxdm
2017-12-22lxdm: fix crash on first bootStefan Agner
The very first start of LXDM always crashes due to an empty last_session configuration in /var/lib/lxdm/lxdm.conf. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Dominik Sliwa <dominik.sliwa@toradex.com>
2017-01-11lxdm bbappend: kill lxsession explicetely with sigkill on poweroffMax Krummenacher
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2017-01-11lxdm bbappend: cleanupMax Krummenacher
Remove stale file, it wasn't referenced in SRC_URI for some time. Remove source uri entry also applied upstream. This would probably error out if not compiling with debug tweaks as the patch would be applied twice. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2017-01-10lxdm bbappend: use version wildcardMax Krummenacher
2016-09-29recipes: stop using base_containsMax Krummenacher
The base_contains function is deprecated and we ought to use bb.utils.contains instead. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2015-05-12recipes: don't use ${PN} as a recipe name placeholderMax Krummenacher
${PN} might be extended with some magic prefix, so don't use it in SRC_URI assignments et. al.
2014-10-29lxdm: switch to 0.5/git versionStefan Agner
Switch to newer LXDM which supports logind as login/session management.
2014-08-04bbappends: remove the deprecated PRINC variableMax Krummenacher
2013-09-22lxdm: path to greeter changed, adapt conf fileMax Krummenacher
2012-10-18lxdm: start it as a systemd serviceMax Krummenacher
2012-10-18lxdm, moved general changes to oe-tworaz/meta-lxdeMax Krummenacher
2012-10-18initscript provided in oe-tworaz/meta-lxdeMax Krummenacher
2012-08-23Use kernel and u-boot from git.toradex.comMax Krummenacher
Move changes done to other repos into .bbappends in meta-toradex
2012-08-15L4T R15, oe-core Image V2.0Beta1Max Krummenacher
2012-07-17append our V1.1 lxde specialities to the oe-tworaz recipesMax Krummenacher
