index
meta-toradex-demos.git
dunfell-5.x.y
jethro
jethro-next
kirkstone-6.x.y
master
morty
morty-next
rocko
rocko-next
thud
thud-next
zeus
Toradex BSP layer, recipes for the demo images
Marcel Ziswiler
summary
refs
log
tree
commit
diff
log msg
author
committer
range
path:
root
recipes-lxde
Age
Commit message (
Collapse
Author
2013-11-21
lxde-common: choose wallpaper for colibri-vf at runtime
Max Krummenacher
2013-10-17
lxpanel: add module dependent browser to launch bar
Max Krummenacher
For tegra use firefox, for vybrid midori
2013-10-10
colibri-vf50: add the machine, kernel and u-boot
Max Krummenacher
- also add the relevant configuration files
2013-09-22
lxdm: path to greeter changed, adapt conf file
Max Krummenacher
2013-09-22
lxlauncher: fix FILES variable
Max Krummenacher
2013-09-22
lxappearance-obconf: update to 0.2.0
Max Krummenacher
2013-03-20
Wallpaper: correct new CI colors
Max Krummenacher
2013-03-04
lxde-common: wallpapers are MACHINE_ARCH dependent
Max Krummenacher
2013-01-29
wallpaper, change to new Toradex CI
Max Krummenacher
2013-01-29
wallpaper, added Apalis-T30
Max Krummenacher
2013-01-23
wallpaper: renamed in preparation of upcomming Apalis
Max Krummenacher
2012-10-18
removed *~ backup files from git repo
Max Krummenacher
2012-10-18
lxdm: start it as a systemd service
Max Krummenacher
2012-10-18
lxpanel, obconf, moved general changes to oe-tworaz/meta-lxde
Max Krummenacher
2012-10-18
lxrandr, changes needed by newer autotools
Max Krummenacher
2012-10-18
lxdm, moved general changes to oe-tworaz/meta-lxde
Max Krummenacher
2012-10-18
initscript provided in oe-tworaz/meta-lxde
Max Krummenacher
2012-08-23
Use kernel and u-boot from git.toradex.com
Max Krummenacher
Move changes done to other repos into .bbappends in meta-toradex
2012-08-15
L4T R15, oe-core Image V2.0Beta1
Max Krummenacher
2012-07-17
append our V1.1 lxde specialities to the oe-tworaz recipes
Max Krummenacher
2012-06-03
Initial commit
Max Krummenacher
