The gstreamer1.0-plugins-imx recipe has been upgraded to 0.13.
It is unclear if the issue with asserts still exists, remove
the work around for now.
Empty RDEPENDS are not needed, the others are automatically added
by the buildsystem.
The recipe now uses feature overrides to chose the PACKAGECONFIG.
Follow that to achive the same effect as the older machine override
did.
Using libimxvpuapi causes asserts when using certain pipelines,
e.g. with gst-play-1.0.
Don't build the plugins which base on libimxvpuapi for now.
remove it also for i.MX6 DL.
Pass $libdir to 'waf configure' to prevent using the build hosts libdir.
Fixes:
WARNING: libimxvpuapi-0.10.2-r0 do_package: QA Issue: libimxvpuapi: Files/directories were installed but not shipped in any package:
/usr/lib64/libimxvpuapi.so
/usr/lib64/libimxvpuapi.so.0
/usr/lib64/libimxvpuapi.so.0.10.2
/usr/lib64/pkgconfig
/usr/lib64/pkgconfig/libimxvpuapi.pc
Signed-off-by: Max Krummenacher <max.krummenacher at toradex.com>
This reverts commit 04324a6e680902d4c1aabeff7187975a6cbf09b0.
The patch is now part of meta-openembedded jethro branch.
Use Stefan's patch until it is available from the meta-openembedded jethro branch.
http://cgit.openembedded.org/meta-openembedded/commit/?h=master-next&id=bf8f27af3954ab68e39712516ab515de90b4db27
Double clicking launches a video always in fullscreen mode, i.e. the parameters
for size and offset of video output are not used.
Fix parmeter escaping for new versions of shell or gst-launch.
The SUMMARY variable gives a short description of the package (<72 chars).
A missing DESCRIPTION is automatically set to the content of SUMMARY.
${PN} might be extended with some magic prefix, so don't use it in SRC_URI
assignments et. al.
HDA debug tool
HDA debug tool
