Using libimxvpuapi causes asserts when using certain pipelines,
e.g. with gst-play-1.0.
Don't build the plugins which base on libimxvpuapi for now.
Pass $libdir to 'waf configure' to prevent using the build hosts libdir.
Fixes:
WARNING: libimxvpuapi-0.10.2-r0 do_package: QA Issue: libimxvpuapi: Files/directories were installed but not shipped in any package:
/usr/lib64/libimxvpuapi.so
/usr/lib64/libimxvpuapi.so.0
/usr/lib64/libimxvpuapi.so.0.10.2
/usr/lib64/pkgconfig
/usr/lib64/pkgconfig/libimxvpuapi.pc
Signed-off-by: Max Krummenacher <max.krummenacher at toradex.com>
This reverts commit 04324a6e680902d4c1aabeff7187975a6cbf09b0.
The patch is now part of meta-openembedded jethro branch.
Use Stefan's patch until it is available from the meta-openembedded jethro branch.
http://cgit.openembedded.org/meta-openembedded/commit/?h=master-next&id=bf8f27af3954ab68e39712516ab515de90b4db27
Double clicking launches a video always in fullscreen mode, i.e. the parameters
for size and offset of video output are not used.
Fix parmeter escaping for new versions of shell or gst-launch.
The SUMMARY variable gives a short description of the package (<72 chars).
A missing DESCRIPTION is automatically set to the content of SUMMARY.
${PN} might be extended with some magic prefix, so don't use it in SRC_URI
assignments et. al.
HDA debug tool
HDA debug tool
