path: root/recipes-multimedia
2015-06-23Apalis/Colibri iMX6: gst-launch.desktop: fix escapingMax Krummenacher
Double clicking launches a video always in fullscreen mode, i.e. the parameters for size and offset of video output are not used. Fix parmeter escaping for new versions of shell or gst-launch.
2015-05-12recipes: replace short DESCRIPTION with SUMMARYMax Krummenacher
The SUMMARY variable gives a short description of the package (<72 chars). A missing DESCRIPTION is automatically set to the content of SUMMARY.
2015-05-12recipes: don't use ${PN} as a recipe name placeholderMax Krummenacher
${PN} might be extended with some magic prefix, so don't use it in SRC_URI assignments et. al.
2014-08-04bbappends: remove the deprecated PRINC variableMax Krummenacher
2014-04-01mimetypes: add mimetypes for some basic multimedia typesMax Krummenacher
2013-09-22v4l2-utils: removed patch, fixed upstream nowMax Krummenacher
2013-09-22hda-verb: add recipeMax Krummenacher
HDA debug tool
2013-09-22codecgraph: add recipeMax Krummenacher
HDA debug tool
2013-09-22mediainfo: dont hardcode build architectureMax Krummenacher
2013-09-22gstreamer: make sure plugin package gets generated, disable sdlMax Krummenacher
2013-04-15mediainfo: added mediainfo recipeMax Krummenacher
2013-02-06v4l-utils: fix for NULL not found errosMax Krummenacher
