2016-06-30 | Revert "gstreamer: fix argument parsing when using Bison 3" | Max Krummenacher | |
This reverts commit 04324a6e680902d4c1aabeff7187975a6cbf09b0. The patch is now part of meta-openembedded jethro branch. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> | |||
2016-03-30 | gstreamer: fix argument parsing when using Bison 3 | Max Krummenacher | |
Use Stefan's patch until it is available from the meta-openembedded jethro branch. http://cgit.openembedded.org/meta-openembedded/commit/?h=master-next&id=bf8f27af3954ab68e39712516ab515de90b4db27 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> | |||
2015-10-28 | gst-launch: follow mfw_v4lsink to imxv4l2sink name change | Max Krummenacher | |
2015-06-23 | Apalis/Colibri iMX6: gst-launch.desktop: fix escaping | Max Krummenacher | |
Double clicking launches a video always in fullscreen mode, i.e. the parameters for size and offset of video output are not used. Fix parmeter escaping for new versions of shell or gst-launch. | |||
2015-05-12 | recipes: replace short DESCRIPTION with SUMMARY | Max Krummenacher | |
The SUMMARY variable gives a short description of the package (<72 chars). A missing DESCRIPTION is automatically set to the content of SUMMARY. | |||
2015-05-12 | recipes: don't use ${PN} as a recipe name placeholder | Max Krummenacher | |
${PN} might be extended with some magic prefix, so don't use it in SRC_URI assignments et. al. | |||
2014-08-04 | bbappends: remove the deprecated PRINC variable | Max Krummenacher | |
2014-04-01 | mimetypes: add mimetypes for some basic multimedia types | Max Krummenacher | |
2013-09-22 | v4l2-utils: removed patch, fixed upstream now | Max Krummenacher | |
2013-09-22 | hda-verb: add recipe | Max Krummenacher | |
HDA debug tool | |||
2013-09-22 | codecgraph: add recipe | Max Krummenacher | |
2013-09-22 | mediainfo: dont hardcode build architecture | Max Krummenacher | |
2013-09-22 | gstreamer: make sure plugin package gets generated, disable sdl | Max Krummenacher | |
2013-04-15 | mediainfo: added mediainfo recipe | Max Krummenacher | |
2013-02-06 | v4l-utils: fix for NULL not found erros | Max Krummenacher | |
