path: root/recipes-qt/qt5/qtbase_%.bbappend
2016-11-21qtbase bbappend: configure unconditionally with -accessibilityMax Krummenacher
qtquickcontrols are only built if qtbase gets configured with accessibility. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-09-29recipes: stop using base_containsMax Krummenacher
The base_contains function is deprecated and we ought to use bb.utils.contains instead. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-03-14qtbase_%.bbappend: fix build with X11Max Krummenacher
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2015-06-23qt5: align with meta-qt5 dizzyMax Krummenacher
- use % in bbappend - tegra: build with icu, so qtwebkit can be built - tegra: build with gstreamer 0.10 - remove workaround for gcc 4.8
