path: root/recipes-support/florence
2017-04-07meta-toradex-demo: clean-up whitespace useMax Krummenacher
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-04-07florence3: depends on glib-2.0-nativeMax Krummenacher
Fixes run.do_configure: line 172: glib-gettextize: command not found. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-04-07florence3: add missing dependencyMax Krummenacher
2017-01-10florence: update to 0.6.3 which is based on gtk+3Max Krummenacher
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2016-06-30florence: build without sound and drop gstreamer 0.10 dependencyMax Krummenacher
add configure options to build without sound. This removes the runtime dependency on gstreamer 0.10. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-06-30florence: move to latest GTK2 version 0.5.4Stefan Agner
The latest GTK2 version is 0.5.4, which contains several bug fixes. Noteable, it fixes an issue where the SVG keys have not been displayed with recent versions of its dependencies. Note: This adds GStreamer 0.10 dependency... Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-03-14florence bbappend: remove patches now applied in florence bbMax Krummenacher
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2015-05-12florence: use oe standard download mirror for sourceforgeMax Krummenacher
2015-03-31FILESEXTRAPATHS_prepend: add proper list separatorMax Krummenacher
2014-08-04bbappends: remove the deprecated PRINC variableMax Krummenacher
2013-09-22florence: RDEPEND on svg support to draw iconMax Krummenacher
2013-04-02florence: fix garbled titlebarMax Krummenacher
