2017-12-22 | gnutls: remove backported patches no longer needed | Max Krummenacher | |
The patches are part of gnutls 3.5.7 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> | |||
2017-01-11 | gnutls: backport split initialization in preinit and init | Max Krummenacher | |
From https://bugzilla.redhat.com/show_bug.cgi?id=1387141: Description of problem: GnuTLS initializes its random generator on the library constructor. That has the side effect that applications which load early on boot process may block for significant time even when they wouldn't otherwise use the random generator. connmand is hit by the above issue. Backport the relevant patches. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com> |
