path: root/recipes-support/icu
2015-08-07icu: upgrade reduced icu data to version 54Max Krummenacher
2015-05-12icu: upgrade reduced icu data to version 53Max Krummenacher
While at it move version to % placeholder and use wildcards in receipe icu: use wildcard to be independent of version
2014-08-04bbappends: remove the deprecated PRINC variableMax Krummenacher
2014-04-30icu: add break iterator support for webkitgtkStefan Agner
Webkitgtk needs break iterator support in order to work. This avoids segmentation fault when using Midori web browser.
2014-04-04icu: update to match bb versionMax Krummenacher
2014-03-31icu: is machine specific for colibri-vfMax Krummenacher
For colibri-vf we deploy icu only partly to save diskspace, so set the PACKAGE_ARCH for that machine.
2013-11-21Machine: use the changed machinename colibri-vfMax Krummenacher
2013-10-16icu: fix SRC_URIMax Krummenacher
2013-10-11icu: replace database with minimzed versionMax Krummenacher
