These machines use an old Nvidia provided downstream kernel 3.1.10.
They are no longer compatible with more recent sysroot components,
e.g. libc, xserver et. al.
The maintenance burden to keep the userspace components in their old version
becomes simply to high. Keep using the rocko based 2.8 BSP for these machines.
WARNING: No recipes available for:
layers/meta-toradex-demos/recipes-support/icu/icu_57%.bbappend
layers/meta-toradex-demos/recipes-support/opencv/opencv_2.4.bbappend
Colibri iMX6ULL: The alternate function of the pins in the IOMUXC SNVS is
wrongly displayed. These pins are always GPIO. (TAMPER[0-9], BOOT_MODE[0-1].
Colibri iMX7: SODIMM-55/63, The alternate function 2 (CAN), text corrected.
Stress is nowadays available in the OpenEmbdedded core layer. Remove
the local version.
Beside that, the local version still has an old md5sum due to upstream
license change in 2015. The recipe continued to work since the default
Toradex local.conf uses Toradex source mirrors with the stress package
available using the old md5sum.
Inital version for colibri-imx6ull.
The patches are part of gnutls 3.5.7
Follow Pinmuxing for Apalis TK1 V1.2 Hardware.
The .NET Core framework recommends to use OpenSSL backend by
default, otherwise not all SSL/TLS functions of the framework
are available.
For i.MX6 the pin NANDF_D4 was wrongly muxed.
For TK1 the number of pins was wrong which prevented access to some pins.
Fixes run.do_configure: line 172: glib-gettextize: command not found.
Empty RDEPENDS are not needed, the others are automatically added
by the buildsystem.
From https://bugzilla.redhat.com/show_bug.cgi?id=1387141:
Description of problem:
GnuTLS initializes its random generator on the library constructor. That has
the side effect that applications which load early on boot process may block
for significant time even when they wouldn't otherwise use the random generator.
connmand is hit by the above issue.
Backport the relevant patches.
OE-Core split the package into only native tools and one which uses perl
and fixed the dependencies so that perl is no longer pulled in.
Follow the name change in the WinCE team.
add configure options to build without sound. This removes the runtime
dependency on gstreamer 0.10.
The latest GTK2 version is 0.5.4, which contains several bug fixes.
Noteable, it fixes an issue where the SVG keys have not been displayed
with recent versions of its dependencies.
Note: This adds GStreamer 0.10 dependency...
The SUMMARY variable gives a short description of the package (<72 chars).
A missing DESCRIPTION is automatically set to the content of SUMMARY.
Mechanism changed to what the bb file now offers.
While at it move version to % placeholder and use wildcards in receipe
icu: use wildcard to be independent of version
gnutls recipe now detects pthread in configure task correctly.
To use the kernel interfaces required for mcc-pingpong we need the
kernel headers of the actual kernel. Alter CFLAGS to add the kernel
headers to the include path.
gnutls use libgcrypt and should init gcrypt's mutex functionality but does not.
This leads to asserts in libgcrypt:
Ohhhh jeeee: Assertion `pool_is_locked' failed (random-csprng.c:615:mix_pool)
This patch hacks autoconf to always use libpthread and thus initalizes libgcrypt
with working mutex functions.
This uses the % wildcard for recipe matching.
remove the deprecated PRINC variable while at it.
Webkitgtk needs break iterator support in order to work. This avoids
segmentation fault when using Midori web browser.
