2014-08-04 | bbappends: remove the deprecated PRINC variable | Max Krummenacher | |
2014-08-04 | Use generic bbappend files | Max Krummenacher | |
This uses the % wildcard for recipe matching. remove the deprecated PRINC variable while at it. | |||
2014-05-02 | mcc-pingpong: demo application for ping pong with Cortex M4 | Stefan Agner | |
2014-04-30 | icu: add break iterator support for webkitgtk | Stefan Agner | |
Webkitgtk needs break iterator support in order to work. This avoids segmentation fault when using Midori web browser. | |||
2014-04-04 | icu: update to match bb version | Max Krummenacher | |
2014-03-31 | icu: is machine specific for colibri-vf | Max Krummenacher | |
For colibri-vf we deploy icu only partly to save diskspace, so set the PACKAGE_ARCH for that machine. | |||
2013-11-21 | Machine: use the changed machinename colibri-vf | Max Krummenacher | |
2013-10-16 | icu: fix SRC_URI | Max Krummenacher | |
2013-10-11 | icu: replace database with minimzed version | Max Krummenacher | |
2013-10-09 | i2c-tools: don't install the perl scripts (and thus don't RDEPEND on perl) | Max Krummenacher | |
2013-09-22 | florence: RDEPEND on svg support to draw icon | Max Krummenacher | |
2013-09-22 | libfm: bbappend updated to 1.1 | Max Krummenacher | |
2013-09-22 | libpcre: bbappend update to 8.32 | Max Krummenacher | |
2013-04-02 | florence: fix garbled titlebar | Max Krummenacher | |
2013-02-06 | libfm: set lxterminal as the terminal application | Max Krummenacher | |
2012-10-18 | libvpx, version update in oe-core | Max Krummenacher | |
2012-08-27 | nautilus depends on gobject-introspection-native | Max Krummenacher | |
libpcre splits into libpcre-*, use packages-dynamic so we can put them into an image rename bbappend because coresponding bb does not exist |
