path: root/recipes-support
2015-08-07opencv: update patches for libav 10.x APIMax Krummenacher
2015-08-07icu: upgrade reduced icu data to version 54Max Krummenacher
2015-05-12florence: use oe standard download mirror for sourceforgeMax Krummenacher
2015-05-12opencv: add patches for libav 10.x APIMax Krummenacher
2015-05-12recipes: replace short DESCRIPTION with SUMMARYMax Krummenacher
The SUMMARY variable gives a short description of the package (<72 chars). A missing DESCRIPTION is automatically set to the content of SUMMARY.
2015-05-12i2ctools: don't install the perlscript and perlMax Krummenacher
Mechanism changed to what the bb file now offers.
2015-05-12icu: upgrade reduced icu data to version 53Max Krummenacher
While at it move version to % placeholder and use wildcards in receipe icu: use wildcard to be independent of version
2015-03-31gnutls: remove bbappendMax Krummenacher
gnutls recipe now detects pthread in configure task correctly.
2015-03-31FILESEXTRAPATHS_prepend: add proper list separatorMax Krummenacher
2014-12-18mcc-pingpong: alter CFLAGS to use the actual kernel headersStefan Agner
To use the kernel interfaces required for mcc-pingpong we need the kernel headers of the actual kernel. Alter CFLAGS to add the kernel headers to the include path.
2014-12-11consolekit: add systemd to DEPENDS if neededMax Krummenacher
2014-08-04gnutls: hack to use libpthreadMax Krummenacher
gnutls use libgcrypt and should init gcrypt's mutex functionality but does not. This leads to asserts in libgcrypt: Ohhhh jeeee: Assertion `pool_is_locked' failed (random-csprng.c:615:mix_pool) This patch hacks autoconf to always use libpthread and thus initalizes libgcrypt with working mutex functions.
2014-08-04libpcre: Use generic bbappend versioningMax Krummenacher
2014-08-04bbappends: remove the deprecated PRINC variableMax Krummenacher
2014-08-04Use generic bbappend filesMax Krummenacher
This uses the % wildcard for recipe matching. remove the deprecated PRINC variable while at it.
2014-05-02mcc-pingpong: demo application for ping pong with Cortex M4Stefan Agner
2014-04-30icu: add break iterator support for webkitgtkStefan Agner
Webkitgtk needs break iterator support in order to work. This avoids segmentation fault when using Midori web browser.
2014-04-04icu: update to match bb versionMax Krummenacher
2014-03-31icu: is machine specific for colibri-vfMax Krummenacher
For colibri-vf we deploy icu only partly to save diskspace, so set the PACKAGE_ARCH for that machine.
2013-11-21Machine: use the changed machinename colibri-vfMax Krummenacher
2013-10-16icu: fix SRC_URIMax Krummenacher
2013-10-11icu: replace database with minimzed versionMax Krummenacher
2013-10-09i2c-tools: don't install the perl scripts (and thus don't RDEPEND on perl)Max Krummenacher
2013-09-22florence: RDEPEND on svg support to draw iconMax Krummenacher
2013-09-22libfm: bbappend updated to 1.1Max Krummenacher
2013-09-22libpcre: bbappend update to 8.32Max Krummenacher
2013-04-02florence: fix garbled titlebarMax Krummenacher
2013-02-06libfm: set lxterminal as the terminal applicationMax Krummenacher
2012-10-18libvpx, version update in oe-coreMax Krummenacher
2012-08-27nautilus depends on gobject-introspection-nativeMax Krummenacher
libpcre splits into libpcre-*, use packages-dynamic so we can put them into an image rename bbappend because coresponding bb does not exist
