path: root/recipes/images/files/colibri-t30/colibri-t30_bin/flash_eth.scr
2016-09-28images: mv all files into recipes-image/imageMax Krummenacher
This requires to adjust the path to include files, e.g.: -require recipes/images/trdx-image-fstype.inc +require recipes-images/images/trdx-image-fstype.inc Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2016-08-17apalis/colibri-t30: fix dtb file name in u-boot update scriptsmeta-toradex_splitStefan Agner
Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-03-14flash_eth.scr: allow image sizes > 640M for eMMC modulesMax Krummenacher
When using TFTP update, the rootfs must be in decimal numbered chunks on the tftp server. U-Boot reads the chunks, but does count hexadecimal thus limiting the number of chunks to 10. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2015-11-02apalis/colibri_t20/t30: further generalise u-boot update scriptsMarcel Ziswiler
Further generalise U-Boot update scripts by using ${board_name} instead of hard coding module name like apalis_t30, colibri_t20 or colibri_t30.
2015-11-02apalis/colibri_t30: fix dtb update in u-boot update scriptsMarcel Ziswiler
Even though our downstream L4T based kernel does not use any device tree stuff prepare for easy deployment thereof by using the correct dtb name. In the Ethernet aka TFTP update case this actually fixes an issue where it previously tried to TFTP the whole ${board_name} directory which at least on my setup failed with a permission denied which it retried forever.
2015-10-29apalis/colibri_imx6/t30: update u-boot update scriptsMarcel Ziswiler
Update our U-Boot update scripts to accommodate our new unified eMMC layout: boot area partition 1 aka primary eMMC boot sector: with U-Boot boot loader and the U-Boot environment before the configblock at the end of that boot area partition Handle migration of boot loader and configblock on Apalis/Colibri iMX6. When doing a full update also explicitly flash kernel and FDT from the update medium in order to allow for easy updating thereof.
2015-10-28update.sh: use moduletype specific folder for output filesMax Krummenacher
With update.sh one creates files on e.g. a SD-card or a tftp server which enables updating the SW on a module from U-Boot running on said module. This commit adds a module type specific directory on that output media so that update data for multiple module types can be stored on one media. Generic U-Boot scripts in the media's root directory do select the matching update data depending on module type.
2015-10-28flash_eth: provide option to split output fileMax Krummenacher
To flash a large rootfs over tftp the rootfs must be split into chunks of 64MB on the tftp server. Add the option '-c' to the update.sh script which does this automatically. Use 64MB chunks on all module types.
2015-05-12apalis/colibri_imx6/t20/t30: revamp update scriptsMarcel Ziswiler
iMX6: Always do use a secondary argument for the 'mmc dev' command. T30: Do rootfs update of eMMC in chunks as well. Requires pre-splitting file in Ethernet case. As an advantage allows flashing rootfs bigger than RAM plus avoids timeouts during flashing. Added wrapper flash_mmc script as well for backwards compatibility reason. While at it cleanup various whitespaces throughout the update scripts.
2015-05-12apalis/colibri_t20/t30: integrate latest stuffMarcel Ziswiler
2015-05-12trdx-image-fstype: drop tarball in favour of filesMax Krummenacher
Drop the burnflash.tar.bz2 tarball and put the individual files under version control. Only create minimal set for colibri-t20 for now and move it with the change to tegra-uboot-flasher.
