2014-03-18 | trdx-extra: apalis-t30: add additional camera drivers | Max Krummenacher | |
2014-03-18 | trdx-extra: add mcc components for vybrid | Max Krummenacher | |
The MCC (Multi-Core Communication) is the subsystem that enables MQX applications running on the M4 core to communicate with Linux applications on the A5 core | |||
2014-03-18 | trdx-extra: add gpioconfig to vybrid | Max Krummenacher | |
2014-03-18 | angstrom-lxde-image: T30: add gst-plugins-good-jpeg | Max Krummenacher | |
2014-02-10 | image: improved dependencies to make Qt image smaller | Stefan Agner | |
- move pam-plugin-ck-connector to LXDE image - remove connman-gnome from Qt image | |||
2014-02-05 | image: add kernel module for fusion touch screens | Stefan Agner | |
Add kernel module for Fusion 7"/10" touch screen to the root filesystem image. | |||
2014-02-04 | util-linux: add fstrim | Max Krummenacher | |
Add the fstrim utility to Colibri T30 image. The utility allows to send trim commands to the underlaying flash translation layer, which allows too free not used flash sectors and those improve wear- leveling | |||
2013-12-02 | console-image: use connman | Max Krummenacher | |
2013-11-21 | Machine: use the changed machinename colibri-vf | Max Krummenacher | |
2013-11-21 | qt4e-demo-image: Add missing libicui18n | Max Krummenacher | |
2013-10-21 | hdmi: add udev rule to start an X output on hotplug | Max Krummenacher | |
2013-10-11 | images: add a qt4 embedded image | Max Krummenacher | |
still missing automatic start of a demo (and detecting keyboard, mouse, touch) export QWS_DISPLAY="LinuxFb:/dev/fb:depth=24" export QWS_KEYBOARD="USB:/dev/input/event1" export QWS_MOUSE_PROTO="LinuxInput:/dev/input/event2" qtdemoE -qws | |||
2013-10-11 | console-image: fix the inclusion of X11 | Max Krummenacher | |
2013-10-10 | image-fstype: add colibri-vfxx module | Max Krummenacher | |
2013-10-10 | images: cleanup, add colibri-vfxx module | Max Krummenacher | |
- Add optimizations needed for the Colibri VFxx modules - Move common stuff to trdx-extra.inc, /etc/timestamp, CAN utils - Cleanup whitespace and commented stuff - Split out gstreamer packages, don't add them on Colibri VFxx angstrom-lxde-image: - Browser for Colibri VFxx is midori for size reasons console-image: - don't add X11 for Colibri VFxx | |||
2013-09-22 | images: use consistent image names | Max Krummenacher | |
- use consistent image names - while at it build the GLES samples only for a tegra machine | |||
2013-09-22 | image: add handling for imx u-boot extension | Max Krummenacher | |
2013-09-22 | image: add update-alternative and ethtool | Max Krummenacher | |
2013-09-22 | connman: add commandline configuration tool | Max Krummenacher | |
root@colibri-t30:~# connmanctl connmanctl> services *AO Wired { ethernet_00142d259a48_cable } connmanctl> services ethernet_00142d259a48_cable [ ethernet_00142d259a48_cable ] Type = ethernet Security = [ ] State = online Favorite = True Immutable = False AutoConnect = True Name = Wired Ethernet = { Method=auto Interface=eth0 Address=00:14:2D:25:9A:48 MTU=1500 } IPv4 = { Method=dhcp Address=192.168.10.2 Netmask=255.255.255.0 Gateway=192.168.10.1 } IPv4.Configuration = { Method=dhcp } IPv6 = { } IPv6.Configuration = { Method=auto Privacy=disabled } Nameservers = [ 192.168.0.32 ] Nameservers.Configuration = [ ] Timeservers = [ 192.168.0.32 ] Timeservers.Configuration = [ ] Domains = [ ] Domains.Configuration = [ ] Proxy = { Method=direct } Proxy.Configuration = { } Provider = { } connmanctl> config ethernet_00142d259a48_cable --ipv4 manual 192.168.10.2 255.255.255.0 192.168.10.1 connmanctl> exit root@colibri-t30:~# connmanctl connmanctl> config ethernet_00142d259a48_cable --ipv4 dhcp connmanctl> exit | |||
2013-09-22 | lxde: use renamed recipe packagegroup* recipe | Max Krummenacher | |
2013-09-22 | update-modules: this package is replaced by other postinst | Max Krummenacher | |
2013-09-22 | console-image: use require instead of include | Max Krummenacher | |
2013-09-22 | image: remove line concatenations '\' from comments | Max Krummenacher | |
2013-08-19 | apalis image: add the v4l camera driver kernel modules | Max Krummenacher | |
2013-08-19 | image: add v4l-utils | Max Krummenacher | |
2013-07-26 | trdx-config: remove obsolete package | Max Krummenacher | |
2013-06-26 | image: move the pixbuf loader update to rootfs creation | Max Krummenacher | |
2013-06-26 | fs-init: add recipe to extend rootfs partition on eMMC | Max Krummenacher | |
- on Colbri/Apalis T30 the rootfs is downloaded in a minimum size. On first boot this filesystem is resized to fill its full partion. This slows down IO responsivness during the first 5 minutes. | |||
2013-06-26 | burnflash: unified T20/T30 | Max Krummenacher | |
- unified the burnflash sources to work on Colibri T20/T30, Apalis T30 - change the PXA dummy burnflash accordingly - increase the initial free rootfs space to 100M on eMMC partition will be resized on first boot to full partition size relevant for Colibri T30, Apalis T30 | |||
2013-06-26 | image: add gstreamer deinterlacer used with camera | Max Krummenacher | |
2013-06-07 | lxde-image: add scrot, add underscore to apalis tar filename | Max Krummenacher | |
2013-04-15 | trdx-extra: cleanup indention | Max Krummenacher | |
2013-03-27 | images: added a QT4 X11 image | Max Krummenacher | |
- bbappends to the base qt4-x11-free recipe to use OpenGL ES2 - script which starts X plus qtdemo, including a systemd service to activate script | |||
2013-03-20 | florence: add virtual keyboard to image | Max Krummenacher | |
2013-03-07 | image: add setxkbmap package | Max Krummenacher | |
2013-03-04 | remove unused files | Max Krummenacher | |
2013-03-04 | image: remove intermediate file before creating tarball | Max Krummenacher | |
2013-03-04 | added filesystem tools, Apalis: added lvds configuration scripts | Max Krummenacher | |
2013-02-05 | image: image name now defined in the image.bb files | Max Krummenacher | |
2013-01-29 | max9526: install on all modules | Max Krummenacher | |
2013-01-29 | image: add Apalis-T30 specific packages | Max Krummenacher | |
2013-01-29 | burnflash: add Apalis-T30 as a deployable image | Max Krummenacher | |
2012-12-07 | images: add gstreamer plugin mp3, WiFi Firmware, usb-rndis | Max Krummenacher | |
- provide gstreamer plugins which now are required for nvidias mp3 decoder - add firmware for Ambicom WL250N-USB WiFi, - add configuration for usb-rndis | |||
2012-11-26 | image: | Max Krummenacher | |
- add rootfs version to the banner (/etc/issue) | |||
2012-11-22 | burnflash: | Max Krummenacher | |
- prepare for T30 launch - put the rootfs version in the login banner /etc/issue | |||
2012-11-19 | console-trdx-image: | Max Krummenacher | |
- add xserver, and as examples xterm, xclock - cleanup and unify with angstrom-lxde-image | |||
2012-11-19 | trdx-extra.inc | Max Krummenacher | |
- make adding packages specific to colibri-t20, t30 conditonal | |||
2012-10-19 | systemd config: start connman.service, NFS boot issue fixed | Max Krummenacher | |
2012-10-18 | image: add gst plugin for v4l2, remove connman.service in favour of sysv ↵ | Max Krummenacher | |
script (nfs boot) | |||
2012-10-18 | angstrom-lxde-image: remove sysvinit scripts which interfere with systemd ↵ | Max Krummenacher | |
remove psplash which interfers with systemd nvsamples now compile and run, build ipk again |
