BAD_RECOMMENDATIONS seems to not work if more than one package is given
and all packages get installed.
So only give one.
On top of that, if a package is available from multiple feeds the
package gets installed.
Don't install gnome-disk-utility on Vybrid based modules to save space.
u-boot-fw-utils allows for U-Boot environmenmt access from Linux
gpio-export exports the unused GPIOs
usb-rndis sets up RNDIS and a DHCP server on the usb0 NIC
Use the available set of GSTREAMER packages and append the i.MX6 specific ones
to the list instead of providing a new list
Append instead of overwritting the DEPENDS variable.
gnome-disk-utility is no longer implicitely included.
Set image version to V2.3
do_rootfs is now written in python, so no appends with shell scripts.
Replace appends with new tasks.
Set the default systemd target on images that launch X as this is no
longer the default.
Remove the unneeded LIC_FILES_CHKSUM
Patch pending in meta-angstrom
Don't fail for images which do not deploy /boot/uImage
mx6: only strip binaries
With the change to our own u-boot recipes the bbappend to
the common u-boot-fw-utils recipe is no longer a sane solution.
While at it cleanup COMPATIBLE_MACHINE style.
- build and deploy imx_usb, imx_uart
- currently it builds for the build host arch, i.e x86-64 or i386
tinylogin has been deprecated and the functionality ported into busybox,
so we switch to using busybox as the default login manager.
http://cgit.openembedded.org/openembedded-core/commit/?id=54fc2a698d49f7acc93c8e4b6f6c4e7b3b6ffcc8
Apalis T30 and Colibri VFxx modules have IEEE 1588 (Precision Time Protocol)
capable Ethernet NIC's.
This adds the userspace daemon to such hardware.
The MCC (Multi-Core Communication) is the subsystem that enables MQX
applications running on the M4 core to communicate with Linux
applications on the A5 core
- move pam-plugin-ck-connector to LXDE image
- remove connman-gnome from Qt image
Add kernel module for Fusion 7"/10" touch screen to the root
filesystem image.
Add the fstrim utility to Colibri T30 image. The utility allows to
send trim commands to the underlaying flash translation layer, which
allows too free not used flash sectors and those improve wear-
leveling
still missing automatic start of a demo
(and detecting keyboard, mouse, touch)
export QWS_DISPLAY="LinuxFb:/dev/fb:depth=24"
export QWS_KEYBOARD="USB:/dev/input/event1"
export QWS_MOUSE_PROTO="LinuxInput:/dev/input/event2"
qtdemoE -qws
- Add optimizations needed for the Colibri VFxx modules
- Move common stuff to trdx-extra.inc, /etc/timestamp, CAN utils
- Cleanup whitespace and commented stuff
- Split out gstreamer packages, don't add them on Colibri VFxx
angstrom-lxde-image:
- Browser for Colibri VFxx is midori for size reasons
console-image:
- don't add X11 for Colibri VFxx
- use consistent image names
- while at it build the GLES samples only for a tegra machine
root@colibri-t30:~# connmanctl
connmanctl> services
*AO Wired { ethernet_00142d259a48_cable }
connmanctl> services ethernet_00142d259a48_cable
[ ethernet_00142d259a48_cable ]
Type = ethernet
Security = [ ]
State = online
Favorite = True
Immutable = False
AutoConnect = True
Name = Wired
Ethernet = { Method=auto Interface=eth0 Address=00:14:2D:25:9A:48 MTU=1500
IPv4 = { Method=dhcp Address=192.168.10.2 Netmask=255.255.255.0 Gateway=192.168.10.1 }
IPv4.Configuration = { Method=dhcp }
IPv6 = { }
IPv6.Configuration = { Method=auto Privacy=disabled }
Nameservers = [ 192.168.0.32 ]
Nameservers.Configuration = [ ]
Timeservers = [ 192.168.0.32 ]
Timeservers.Configuration = [ ]
Domains = [ ]
Domains.Configuration = [ ]
Proxy = { Method=direct }
Proxy.Configuration = { }
Provider = { }
connmanctl> config ethernet_00142d259a48_cable --ipv4 manual 192.168.10.2 255.255.255.0 192.168.10.1
connmanctl> exit
connmanctl> config ethernet_00142d259a48_cable --ipv4 dhcp
connmanctl> exit
