2014-02-05 | image: add kernel module for fusion touch screens | Stefan Agner | |
Add kernel module for Fusion 7"/10" touch screen to the root filesystem image. | |||
2014-02-04 | util-linux: add fstrim | Max Krummenacher | |
Add the fstrim utility to Colibri T30 image. The utility allows to send trim commands to the underlaying flash translation layer, which allows too free not used flash sectors and those improve wear- leveling | |||
2013-12-18 | stress: fix build, texinfo errors | Max Krummenacher | |
newer distro's tools give the following errors. stress.texi:68: @itemx must follow @item ported from meta-linaro: From e8ba4b6db2c3ec2be54f74d0177bbce2df3f0714 Mon Sep 17 00:00:00 2001 From: Riku Voipio <riku.voipio@linaro.org> Date: Mon, 1 Jul 2013 12:36:23 +0300 Subject: [PATCH] meta-linaro: fix stress build incompatible texinfo changes broke this build | |||
2013-12-02 | console-image: use connman | Max Krummenacher | |
2013-11-21 | Machine: use the changed machinename colibri-vf | Max Krummenacher | |
2013-11-21 | qt4e-demo-image: Add missing libicui18n | Max Krummenacher | |
2013-10-23 | glmark2: add missing dependencies | Max Krummenacher | |
2013-10-21 | feed-config: use the new feed armv7ahf-vfp-neon for T30/VF50 | Max Krummenacher | |
2013-10-21 | hdmi: add udev rule to start an X output on hotplug | Max Krummenacher | |
2013-10-17 | inputrc: use <HOME> <END> to go to begin/end of line | Max Krummenacher | |
2013-10-16 | machines: T30 and VF50 consitstently use NEON and hard float | Max Krummenacher | |
- Colibri T30 and Apalis T30 changed to NEON - Colibri VF50 changed to hard float This makes packages built for T30 incompatible with Colibri T20 (but Colibri T20 packages can still be used on T30) | |||
2013-10-11 | images: add a qt4 embedded image | Max Krummenacher | |
still missing automatic start of a demo (and detecting keyboard, mouse, touch) export QWS_DISPLAY="LinuxFb:/dev/fb:depth=24" export QWS_KEYBOARD="USB:/dev/input/event1" export QWS_MOUSE_PROTO="LinuxInput:/dev/input/event2" qtdemoE -qws | |||
2013-10-11 | feed-config: remove non working feeds, add feeds for T30 VF50 | Max Krummenacher | |
- remove links to incompatible architecture feeds - for Colibri T30, Apalis T30 and Colibri VF50 there are compatible feeds - for Colibri T20 there are no compatible feeds | |||
2013-10-11 | console-image: fix the inclusion of X11 | Max Krummenacher | |
2013-10-10 | colibri-vf50: add the machine, kernel and u-boot | Max Krummenacher | |
- also add the relevant configuration files | |||
2013-10-10 | image-fstype: add colibri-vfxx module | Max Krummenacher | |
2013-10-10 | images: cleanup, add colibri-vfxx module | Max Krummenacher | |
- Add optimizations needed for the Colibri VFxx modules - Move common stuff to trdx-extra.inc, /etc/timestamp, CAN utils - Cleanup whitespace and commented stuff - Split out gstreamer packages, don't add them on Colibri VFxx angstrom-lxde-image: - Browser for Colibri VFxx is midori for size reasons console-image: - don't add X11 for Colibri VFxx | |||
2013-09-22 | images: use consistent image names | Max Krummenacher | |
- use consistent image names - while at it build the GLES samples only for a tegra machine | |||
2013-09-22 | image: add handling for imx u-boot extension | Max Krummenacher | |
2013-09-22 | image: add update-alternative and ethtool | Max Krummenacher | |
2013-09-22 | connman: add commandline configuration tool | Max Krummenacher | |
root@colibri-t30:~# connmanctl connmanctl> services *AO Wired { ethernet_00142d259a48_cable } connmanctl> services ethernet_00142d259a48_cable [ ethernet_00142d259a48_cable ] Type = ethernet Security = [ ] State = online Favorite = True Immutable = False AutoConnect = True Name = Wired Ethernet = { Method=auto Interface=eth0 Address=00:14:2D:25:9A:48 MTU=1500 } IPv4 = { Method=dhcp Address=192.168.10.2 Netmask=255.255.255.0 Gateway=192.168.10.1 } IPv4.Configuration = { Method=dhcp } IPv6 = { } IPv6.Configuration = { Method=auto Privacy=disabled } Nameservers = [ 192.168.0.32 ] Nameservers.Configuration = [ ] Timeservers = [ 192.168.0.32 ] Timeservers.Configuration = [ ] Domains = [ ] Domains.Configuration = [ ] Proxy = { Method=direct } Proxy.Configuration = { } Provider = { } connmanctl> config ethernet_00142d259a48_cable --ipv4 manual 192.168.10.2 255.255.255.0 192.168.10.1 connmanctl> exit root@colibri-t30:~# connmanctl connmanctl> config ethernet_00142d259a48_cable --ipv4 dhcp connmanctl> exit | |||
2013-09-22 | inhibit missing debug info warnings in binary package | Max Krummenacher | |
2013-09-22 | stress: correct license text | Max Krummenacher | |
remove backup file while at it | |||
2013-09-22 | lxde: use renamed recipe packagegroup* recipe | Max Krummenacher | |
2013-09-22 | remove obsolete files | Max Krummenacher | |
2013-09-22 | libxi: provide dummy recipe - libxi.bbappend in a layer breaks build | Max Krummenacher | |
2013-09-22 | update-modules: this package is replaced by other postinst | Max Krummenacher | |
2013-09-22 | console-image: use require instead of include | Max Krummenacher | |
2013-09-22 | image: remove line concatenations '\' from comments | Max Krummenacher | |
2013-09-22 | gpioconfig: fix RDEPENDS to include ${PN} | Max Krummenacher | |
2013-08-19 | apalis image: add the v4l camera driver kernel modules | Max Krummenacher | |
2013-08-19 | image: add v4l-utils | Max Krummenacher | |
2013-07-26 | trdx-config: remove obsolete package | Max Krummenacher | |
2013-06-26 | image: move the pixbuf loader update to rootfs creation | Max Krummenacher | |
2013-06-26 | fs-init: add recipe to extend rootfs partition on eMMC | Max Krummenacher | |
- on Colbri/Apalis T30 the rootfs is downloaded in a minimum size. On first boot this filesystem is resized to fill its full partion. This slows down IO responsivness during the first 5 minutes. | |||
2013-06-26 | burnflash: unified T20/T30 | Max Krummenacher | |
- unified the burnflash sources to work on Colibri T20/T30, Apalis T30 - change the PXA dummy burnflash accordingly - increase the initial free rootfs space to 100M on eMMC partition will be resized on first boot to full partition size relevant for Colibri T30, Apalis T30 | |||
2013-06-26 | image: add gstreamer deinterlacer used with camera | Max Krummenacher | |
2013-06-17 | stress: download site is down, added mirror | Max Krummenacher | |
2013-06-07 | lxde-image: add scrot, add underscore to apalis tar filename | Max Krummenacher | |
2013-04-15 | trdx-extra: cleanup indention | Max Krummenacher | |
2013-03-27 | images: added a QT4 X11 image | Max Krummenacher | |
- bbappends to the base qt4-x11-free recipe to use OpenGL ES2 - script which starts X plus qtdemo, including a systemd service to activate script | |||
2013-03-20 | florence: add virtual keyboard to image | Max Krummenacher | |
2013-03-07 | image: add setxkbmap package | Max Krummenacher | |
2013-03-04 | remove unused files | Max Krummenacher | |
2013-03-04 | image: remove intermediate file before creating tarball | Max Krummenacher | |
2013-03-04 | added filesystem tools, Apalis: added lvds configuration scripts | Max Krummenacher | |
2013-02-15 | max9526: added a gtk version for Colibries only | Max Krummenacher | |
2013-02-05 | GPIOConfig: Colibri-t30 GPIO to SODIMM assignment | Max Krummenacher | |
- Colibri T30 V1.1 has a different assignment of GPIO to SODIMM pins | |||
2013-02-05 | image: image name now defined in the image.bb files | Max Krummenacher | |
2013-01-29 | max9526: install on all modules | Max Krummenacher | |
